Thermostat leaking on my RS
Old 15-12-2007, 05:21 PM
Leggy Pete
Leggy Pete's Avatar
Default Thermostat leaking on my RS
Is this a DIY job and what parts are needed or garage job.
Cheers Pete
Old 15-12-2007, 05:23 PM
gkandr4ch
gkandr4ch's Avatar
Yeah you will be ok doing this. I presume this is an Escort? If it is, you will be fine.
Gasket sealant and gasket is needed and you might as well put a new thermostat in.
Old 15-12-2007, 06:11 PM
Leggy Pete
Leggy Pete's Avatar
No its a Focus RS but thanks.
Old 17-12-2007, 08:11 AM
Davemurphy007
Ford Focus Specialist
Davemurphy007's Avatar
It's not a difficult job to do.
Luckily Ford sell the gasket/rubber o-ring on its own now so it'll only cost a couple of quid instead of about Ł75 (or whatever stupid price is it!) for a complete new thermostat!
Drain your coolant then I 'think' there are 3 bolts holding the thermostat onto the side of the block, change the o-ring over then refit........you might find it easier to remove the coolant pipes (as you've drained all the fluid anyway) but you should be able to do it with them connected.
Then just refill and circulate to make sure you don't get any air pockets!
Old 23-12-2007, 07:59 PM
phill295
phill295's Avatar
i would replace the termostat houseing also as it is not always just the rubber seal have done many of these on normal focus 2.0lts and it is easier to replace the front housing and stat with new gasket all in one.
the 3 srews are normaly torx and very easy to strip so just buy 3 new ones.
hope this helps
Old 23-12-2007, 11:30 PM
bassboy
bassboy's Avatar
are these thermostats the same as a normal zetec?
bassboy
Old 24-12-2007, 09:34 AM
rabmc
rabmc's Avatar
Yes i would repalce the whole lot, most times it still leaks
At least if you do this its a defo that it will be fixed and will save draining coolant etc etc a few times and should see a couple of years use before it does it again
timsrs
13-11-2018 11:48 AM
Chas
05-10-2015 07:13 PM
Fudgey
21
30-09-2015 06:19 PM
The Enigma
29-09-2015 10:31 AM
BRAMMER
15
14-09-2015 08:52 PM
Quick Reply: Thermostat leaking on my RS
