ESCORT RS TURBO WHEELS ON A FOCUS?
Basically been offered some rs turbo wheels (90 spec) with cracking tyres and they are mint! I know the stud pattern is the same but will they fit on a 2002 1.6 ghia focus?
plan is to use them over the winter, concerned that the offset may be off and catch on front brakes?
I know best way is to try them but that is logistically difficult at the moment.
anyone know off hand?
Fast Ford snapper
Quite sure both are ET35, should fit just fine even if they'll look a bit odd on it
Focus wil use a taller tyre as standard though, 2 profiles up IIRC, so this would make your car have lower gearing too if using std RST 195/50-15 tyres
Ford Focus Specialist
Stud pattern will be the same. Offsets will be an issue though...........
If it's ET35 it'll majorly fuck up the handling of the car!
RST wheels are 15" right? Not much of an upgrade over the standard 15" wheels if I'm honest, especially as the offset are a country mile out from what's recommended!!!
