throttle bodies
Old 17-04-2007, 04:24 PM
cpaul4
cpaul4's Avatar
Default throttle bodies
Looking to get some on my focus its a 1600 on an 04 plate. anyone on here know someone who will do them, or can make them.
Chris
Old 18-04-2007, 07:46 AM
johnathan
johnathan's Avatar
some info i ofund out when i was looking into it
Jenvey are doing a set of throttle bodies for the Zetec S family of engines. The shaw speed conversion is a bit of a bodge really, as any other throttle body conversion needs an inlet manifold, and it is virtually impossible to get clearance for the alternator on a Focus or Puma.
The Jenvey ones are straight to head and need no inlet manifold. They are saying the price will be ?556 +VAT and come with fuel rail.
You will need some ECU solution as the stock one will not run these.
You will also need ram pipes, air filters and probably some way to mess about with fuel pressure (maybe an FSE power boost valve).
THey whole thing really starts to make sense with head cam and exhaust work, as no one is really sure what if any difference this will make on a stock engine.
Herwe is a link to the website
http://www.jenvey.co.uk
it is alot of money for the amount of bhp imo. but if u want it go for it
Old 18-04-2007, 08:09 AM
OldDan
OldDan's Avatar
Why is it a bodge? The one Jon has just done had direct to head bodies?????
Old 18-04-2007, 08:11 AM
OldDan
OldDan's Avatar
And standard head on a 1.6 is good for 190bhp, so unless you're going for some wild cams, you're not gonna need the head work....
A decent 4-2-1 Manifold is a must, as is after market management, and with standard cams you could probably be seeing 140-150bhp with just the TBs.
Old 18-04-2007, 08:26 AM
johnathan
johnathan's Avatar
just what i was told mate, someone had looked into it quite alot, and they were saying that. had no reason to doubt them. as i was lookin at there set up
Old 18-04-2007, 08:27 AM
johnathan
johnathan's Avatar
havin said that alot of people have get there kits on the cars and i aint heard any bad stuff. in fact aint u got some of there stuff on ur car?
Old 18-04-2007, 04:35 PM
cpaul4
cpaul4's Avatar
ok cheers guys, ive got a 4-2-1 mani and a decat pipe and system from miltek and also kent cams, so a remap and tb's would be the next step i think. ive looked at the jenvy ones and they look pritty good, shaw speed look ok but were 2k.
chris
Old 18-04-2007, 08:19 PM
OldDan
OldDan's Avatar
That's including an Omex ECU....... You're gonna look at the same price with Jenvey, as you need an aftermarket ecu too.
mk3ste
17-10-2021 10:09 AM
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
Brickhouse
14
03-10-2015 07:28 PM
Quick Reply: throttle bodies
