Oil pressure sensor removal
ON the RS
getting finaly rd to fitting the SPA gauge coolant temp / oil pressure.
Coolant temp piece of cake..into the top rad hose.
In best Blue Peter style you remove the Ford sensor and replace with an adaptor so you can piggy back the sensors (Ford & SPA )
Can anyone shed some light on how the do I remove the the Ford sensor as I cant .Have tried Cut down ring spanners and I haven't got a deep 23-24 mm socket ,normal socket won't go over the sender.
So any peeps who have fitted this item it would be nice to hear fm you
The sensor is hard up against the oil cooler /filter for those who dont know and there is room to swing a vvvvv small mouse let alone 2 big hands.
Ahhhhhhhhhhhhhhhhhh
Thanks
Nick
0311
Ahhhhhhhhhhhhhhhhhh
Thanks
Nick
0311
mrmann
20-08-2015 11:24 PM
