Focus rs not feeling good!!
When the car is cold it run’s like shit when I change gear after you have just started it there no acceleration and once it has warmed up it misses a beat when sitting still and sometime you get a jolt when accelerating hard.
I have changed the sparks so it’s not them.
Anyone got any ideas could it be the management
Cheers,
Jim
Cheers,
Jim
no af is the actual map, the earlier ones were ae map. If the car was fine before then it won't be the map causing the problem it will be something else. I think you will find ae map was the ones with the problem with cold starting but even then that was OK once it had ticked over and fired.
track.focus'd
12-08-2015 05:53 PM
