Turbo strip out
All sorts, I'll need my bluefin remapped to allow for more boost.
I think they are changing the compressor wheels to GT28 spec and a few other mods, possibly roller bearings.
It's the first one they have done, a sort of a one off so I'll give you full spec when it comes back.
Got this from Turbo Technics for comparison but Pat assures me Turbo Dynamics is the way to go!!!
Some information regarding the TT Focus RS Hybrid turbo,
The turbo is based upon the std item,
A T28 Shaft wheel is fitted along with T28 compressor wheel
Original turbine housing is machined to accommodate the shaft wheel
360 Thrust bearing
Uprated actuator set to 0.9 Bar
Fits onto original exhaust manifold and picks up all original pipe work
With the correct induction and exhaust system and mapping the turbo will flow enough air to give approximately 300-320Hp
£588.00 plus vat and shipping
We would need your existing turbo to work on
Pete Bland
360 Thrust bearing
Pete Bland
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
