focus rev counter wire....what colour is it on the multiplug
Old 13-03-2006, 06:09 PM
mk5cos
mk5cos's Avatar
Default focus rev counter wire....what colour is it on the multiplug
as above. fitting a rev counter with shift light. what colour is the rev counter wire on the multi plug behind the clocks? i dont have a tester on me to check. any help much much appreciated.
Old 14-03-2006, 07:12 PM
Mutton
Mutton's Avatar
Unfortunately the Focus doesn't have a separate rev counter input to the instrument cluster - the Tacho gets the signal through the SCP comms line (as does the Speedo and Temp gauges). What type of signal does your new rev counter use as it looks like it will have to receive it's input from another source, although I'm not sure where.
Old 15-03-2006, 02:15 PM
mk5cos
mk5cos's Avatar
its just a standard one as you say. i had it on my cossie thouigh. where is the sensor for the revs in the engine bay? it use to work of the ignition coil in the old days...
TPM961
15-01-2018 10:50 AM
Kam B
24-09-2015 10:40 AM
jonfoc
11-09-2015 04:46 PM
3drpete
10-09-2015 09:11 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: focus rev counter wire....what colour is it on the multiplug
