Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2004 TDCI with air in the fuel system
Old 19-01-2017, 08:36 AM
Gregr68
Gregr68's Avatar
Default 2004 TDCI with air in the fuel system
Hi people
I'm new to the forum, but have a issue with 2004 1.8 TDCI which just refuses to start.
Its had a problem since I bought it (privately) in that fuel drains back from the pump/filter stopping the car from starting. This is a lot worse in the winter than the summer, which would infer an air leakage due to temperature shrinkage.
If I prime the filter either from the tank or separate source, the car starts / runs without issue, but if its then turned off for a short period it fails to start again.
I've checked the tank and fuel lines for blockages and there's none. I've changed the cam sensor / inlet metering valve / fuel rail pressure regulator due to a fuel pressure error code, but still nothing. Ive also changed back to a FORD filter as recommended in case of any air gaps etc. but no joy.
Anyone any ideas as to what could be causing the problem?
Greg
Old 31-01-2017, 03:16 PM
Gregr68
Gregr68's Avatar
Guys and Girls any comments / advise on this would be appreciated
Old 31-01-2017, 03:23 PM
BLU
BLU is the new black :)
BLU's Avatar
The usual suspect is leak off pipes or leak off seals. Have a look around the injectors, see if there any dampness. Failing that it'll probably be a pipe thats split or rubbed through somewhere. Have a good nose at all the fuel pipes and look for signs of damp or rubbing.
Old 31-01-2017, 05:15 PM
Gregr68
Gregr68's Avatar
Thanks for this BLU. There's never been a sign of dampness around any of the injectors and I've done a basic check over of the pipes and all seems to be in order. Is it possible for a leak off seal to go without diesel leakage? Also is it possible to buy a complete set of leak off pipes / seals etc from anywhere other than Fords if they are required?
Cheers Greg
Old 01-02-2017, 10:13 AM
BLU
BLU's Avatar
Cheers Greg
Possible yes, but unusual. There is usually some sign of diesel at the leak, even if its just weeped a tad. It could be any of the diesel pipes or a seal. You need to follow the pipes with a fine tooth comb from the tank to the engine, it'll be there somewhere.
As for pipes not entirely sure. eBay is good for getting cheap dealer only parts
Gregr68 (03-02-2017)
Old 03-02-2017, 09:36 AM
Gregr68
Gregr68's Avatar
BLU, I'll have a another look but there's no leakage of diesel anywhere on the system and difficult to determine a leak on the pipe seals without signs of diesel. Can you think of a way for this to be achieved. I'm thinking something that would work in situ as removal of pipes etc has been fruitless so far.
