Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Anyone good with the Tdci 1.8 110bhp?
Old 17-10-2015, 09:37 AM
Harryh24
Harryh24's Avatar
Default Anyone good with the Tdci 1.8 110bhp?
A brief story, engine let go in the van so I got an exchange unit as was easiest option, fitted all ok new filters fuel included, bled the system then tried to start it splutters and chucked a load of smoke out but won't ever fire. I checked fault codes and it read rail pressure low, when I read the live data it's only showing 400-500psi which is no where near enough.
I've checked leak off on injectors and nothing comes out. I've checked the return and only a dribble is returning.
My guess is the pump, but I've no idea why it would go all of a sudden as was perfect before? Engine dropped a rod but was running fine.
Old 17-10-2015, 01:38 PM
RichieST
RichieST's Avatar
Are you using your original injectors / pump etc or did the new engine come with them?
If it's got low rail pressure it wont even try to inject. Sounds like it either needs injectors coding back in or it's got an air lock.
Old 17-10-2015, 01:54 PM
Harryh24
Harryh24's Avatar
It's all the old system as bought a bare block, I've actually figured it out since posting this.
It is one of the injectors, which would explain the plumes of smoke as I blocked the feed and it stared up right away.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Oranoco
41
11-02-2016 01:28 PM
DavidK
27-09-2015 02:55 PM
Brickhouse
21-09-2015 04:31 PM
Flatlinedan
18-09-2015 12:41 PM
Quick Reply: Anyone good with the Tdci 1.8 110bhp?
