56 1.8tdci focus engine failure fault any help??????
My focus has a engine fault warning every morning when I turn on the ignition,then when I start car it goes into limp mode but when I drive down the street fault clears and car runs great.took it to my local garage and computer points to accelerator pedal but I'm not convinced,any one else had this problem or does anyone have any ideas help would be greatly appreciated
I have exactly the same problem. You'll find it will get worse. I've been told after a full diagnostic by ford that it's glow plugs. I'm sceptical?
Some other people have mentioned low fuel pressure?
Mmm,problem is getting a little worse,started faulting after I've been out in car and go back shortly after,so car still warm and not really using glow plugs,read that egr valves a problem but cost big £ and when they fail they produce lots of smoke!think I will try fuel filter as I have read this can cause lots of problems also,car was serviced 4 months ago but not sure if it was changed as part of the service!
That's interesting wonder what the average life span is for a set of glow plugs,think I will google that and do a bit of research,wonder of they are expensive might be worth a try,I don't think they too bad of a job,could probably attempt them myself!
