Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Mk3 fiesta water in fuel
Old 23-04-2015, 06:13 PM
CharlieRSTurbo
CharlieRSTurbo's Avatar
Default Mk3 fiesta water in fuel
hi, I've got a mk3 fiesta but water keeps getting into the fuel system,
Checked fuel cap and it has a great seal, anyone else had this problem?
Old 23-04-2015, 08:50 PM
3i Jim
3i Jim's Avatar
Petrol or diesel?
Old 23-04-2015, 10:07 PM
CharlieRSTurbo
Petrol mate
Old 23-04-2015, 10:36 PM
CharlieRSTurbo
I'll give you some more information its a 1.1 carb engine and i've bought it for this reason thinking it might be easy fix because I want to rs turbo it, but before I start the conversion I want it running right first, also the guy I bought it off is a gardener so I'm wondering if he's filling it with Jerry cans of fuel since he probably get fuel cheap off someone which will be crap fuel anyways, I might start with a full fresh tank of fuel from asda petrol station and run a fuel additive system through it, see if that's clears anything.
Old 24-04-2015, 07:55 PM
3i Jim
3i Jim's Avatar
Drain the tank completely and put fresh fuel in and go from there.
Old 05-06-2015, 07:04 PM
CharlieRSTurbo
So for late reply, fully drained fuel out and it's started again with the water in fuel system, in tempted to drill a small hole in the tank and leave it to drain out, which I've heard people used to do back in the day, someone mentioned checking the charcoal canister? But not sure where it is.
Thanks
andyrs1600i
04-09-2015 06:34 PM
Ben26
27-08-2015 08:56 PM
mk3 fiesta cosworth
23-08-2015 10:31 AM
David Potasnick
Ford Fiesta
22-08-2015 10:54 PM
Bosch
04-08-2015 05:14 PM
Quick Reply: Mk3 fiesta water in fuel
