2002-03 fiesta 1.4 water filled spark plug wells!!
Evening all, I know its a common problem but just keep this issue in mind if you have not already had the new washer jets fitted. Water leaking into the spark plug wells is a real issue my sister got one a few months back I did a service on it today and was met with water up to the half way point on the plugs and then once dried out rusty plugs of course so rusty I popped some WD40 on them left them for a hour and then went out to start the car (thinking probably easier to get out if I warm the engine block up. What I got instead was the ceraic portion of the plug fired out of its housing causing me to have to use a screw extractor not the easiest of services lol
CHECK YOUR PLUGS!!!!!
Water filling up plug wells on fiesta
Same problem as with focuses I would think which is the core plugs in the head leaking and filling up plug holes only solution is to replace them under cam cover,not a difficult job.
wheelwizardrefurbs
23-09-2015 09:14 PM
Zoggon
10-08-2015 10:39 AM
