6.5 zs starting issues
Hi guys, noob here
Got a really frustrating fault with the other halfs zs
Petrol 1.6, 62k
A few times a week it struggles to start. Symptom is it'll fire, but feels like it runs in three, if you give it some throttle it cut out. Then if you go to start it again 99% of the time it'll fire no problems. It runs ok and never cuts out whilst driving.
So far I've replaced the plugs leads and coil pack. I've checked the battery which has failed its discharge as sometimes it sounds lazy whilst cranking, so I'm replacing that later today. Is there anything else to replace/check?
Pressure regulator/ cts
Gaz.
Petrol 1.6, 62k
Gaz.
Red_bull
09-08-2015 08:34 AM
CabrioTurbo
01-08-2015 11:04 AM
