Replacing rear coils
I seem to have spent a lot of time asking questions on here recently but, I think the left hand side rear coil has gone on the left hand side of my MK5 fiesta right at the top. I can't tell for sure because I can't see it properly, but If i apply enough force and push down on the back end, there is a faint creaking sound so I think it MAY have gone. Mot is tomorrow (27/03/14) and car already needs some welding to get through but as I'm a bit short of money at the min, if the coils have gone I would like a go myself. Just wondered if this is a difficult procedure, many forums for other cars say the rear is quite simple on FWD cars as you don't have to fiddle around with spring compressors and you just have to disconnect the rear axle, undo the bolts that hold the struts in the boot and they just slide right out?? or something a long those lines....Forgive me if I am woefully wrong, thanks!
Ye its not too difficult at all, more or less a undo the nuts and bolts, swap it over type of thing, not too involved. Basically get the car in the air with the wheel off, support the trailing arm with a jack or something, then undo the nut at the bottom of the strut will need another spanner to hold the nut as you unscrew the bolt). Then just go in the car and undo the nut at the top of the strut, make sure you have something to support the strut with so it doesn't just fall out. To get the spring off its just a case of pulling off the top mounting and circlip, I would use a spring compressor for safety but I do believe it can be done without. Re fitting is just reversing the process, not a difficult job to do.
http://s938.photobucket.com/user/Joe...tml?sort=3&o=0
http://s938.photobucket.com/user/Joe...tml?sort=3&o=1
http://s938.photobucket.com/user/Joe...tml?sort=3&o=2
Pics wont open (my internet really does suck!), how much of the thread was damaged? I'd say provided there is enough left to hold the nut on (and I'm afraid to say it'll be the MOT tester that decides if there's enough I'm afraid) then I'd say you should be ok. If your tester is a sympathetic bloke he might let you off if you explain you had trouble with parts and that the new ones are in transit, gotta be worth a shot?
borboyous
22-08-2015 11:17 AM
155lee
14-08-2015 11:21 AM
