Fiesta Puma Conversion
I am thinking of doing a Puma engine conversion on my Fiesta but wanted to know a couple of things before I do so.
First of all I have a 1.4 Fiesta with the Zetec-S engine is it a straight swap?
Second if I get one from the same year (1997) will the wiring loom plug straight in to the existing loom in my Fiesta?
Third will I need to replace the ECU?
I am going to buy a whole Puma (rusted/mot failure) as its cheaper & will have everything I need I just want to make sure I know exactly what I need as this is the first time I have done an engine swap although my dad has done one many years ago on a different car
Thanks
Thanks
Its a 1.4 engine, its basically the same as the 1.6 but Ford restricted it & lowered the cc
also im not doing my conversion just yet, just want to know a bit more
I see .
I am after a 1.6 Zetec s engine for a project I am doing and it's easier to get turbo piston and bits for a 1.6 than a 1.7 .
I have a old Zetec s with puma running gear that I am going to break
Thanks but it will probably be a couple of months before im able to start the project. Will I need to buy new engine mounts or can I just use the ones from the puma donor car?
mk3ste
17-10-2021 10:09 AM
Steve Escos
01-10-2015 06:57 AM
