engine light
engine light
getting to the last bits on my fiesta now one i am not overly concerned about is the engine light which is not working even on the test with the trip switch. i have various wiring diagrams but if someone put this light out intentionally where would be the best place to cut a wire or remove a fuse.i was going to start at the ecu end i have the pin number for the light (somewhere) then look at the dashboard end .problems arise after this as i have no wiring diagrams that show connector blocks inbetween the two.Its 1.25 zetec 2000 and this is the last thing not working so would like to try and fix if possible also have it working incase it does become a mot test item
