mk1 fiesta engine change
hi im changing the engine in my mk1 fiesta from a 957cc to a 1600 cross flow ive got the chance in buying one from a mk1 escort will it fit in as ive read on the net there mixed responce about it fitting can anyone help me out with some info many thanks
in a word, 'no'
The block is different, the escort being rwd mounts on the sides of the block, the fiesta mounts on a cradle and beside the thermostat housing.
When you do eventually find a fiesta xr2 xflow, you will need the xr2 crossmember and driveshafts also as the 1.6 711m xflow is about an inch longer than the 0.9/1.1 Valencia engine you have.
ok thanks for the help bit of a shame as its a full race 711 engine didnt know if there was some way because some people told me it would fit thats why i asked
The head will be worth having and should fit and if race spec should be big valve but make sure it is a late engine with a flat head or will mess up compression ratio also it may have the unleaded seats which would be a bonus even the xr2 x-flow will be for leaded may save some money in long run
JoeyBoyden
04-01-2024 02:36 PM
JoeyBoyden
18-08-2015 05:56 PM
track.focus'd
12-08-2015 05:53 PM
