Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta (Non RS / ST) Range of cars.
help loss of power fiesta 1.25
Old 21-05-2011, 02:50 PM
t16coupe
t16coupe's Avatar
Default help loss of power fiesta 1.25
a friend came to me for me to have a look at his fiesta as it feels realey down on power and has a sputter at light revs so i changed his plugs but its still the same 3 plugs where light brown and 1 was black so changed his leads he has run out of petrol a couple of times to i know of so i was thinking fuel filter blocked injectors blocked exhaust blocked cat failed?
Old 21-05-2011, 05:52 PM
As it's a 1.25, first thing I would do is do fuel filter, then check co and suspect a buggered lambda, at least they are easy to change out on these, being at the rear of the engine sticking up out the exhaust, can be seriously tight though.
Old 22-05-2011, 05:57 PM
Churtz
Churtz's Avatar
I have seen MAF meters fail on these very often giving them symptoms.
Matt
Old 23-05-2011, 10:19 PM
MO' BENT RIMS
MO' BENT RIMS's Avatar
Matt
+1 my mate had exact same prob
Old 16-03-2020, 05:42 PM
Tom Welsh
Tom Welsh's Avatar
Similar issue here with the idle and lack of power, but only began when engine reassembled after changing rocker gasket. All put back together properly, only airbox on top, spark plug leads and rocker cover removed.
DHMC
Ford Fiesta
30-09-2015 07:15 PM
liamT74
23-09-2015 10:24 PM
mk1focus
Ford Fiesta
21-09-2015 05:46 PM
Dubs44
19-09-2015 06:31 AM
Maxwell
Fiesta ST
13-09-2015 05:31 PM
Quick Reply: help loss of power fiesta 1.25
