Fiesta RS1800/RS Turbo This forum is for discussion of all things pertaining to the Ford Fiesta RS Range of cars.
water pump 1.2 zetec engine remove & Replace
Old 15-04-2011, 01:11 PM
f1bash
f1bash's Avatar
Default water pump 1.2 zetec engine remove & Replace
Hi i have a lowly 1.2 1996 fiesta si fitted with a 1250cc 16 valve zetec engine and power steering. The water pump has siezed solid. I have been told you can replace it without removing the cam belt as i had this done last year. Plus how do i get a auxilary belt off i cannot see how to slaken any thing. If some one could give me a run down on how to remove and replace the water pump i would be greatefull. I know you guys have the souped up fiestas but can some one help a old 60 year old out. Cheers f1bash
Old 15-04-2011, 01:16 PM
chaffe
Turbocharging Technician
chaffe's Avatar
automatic sprung loaded tensioner, plus that is a yamaha engine, all alloy block, wont take much of a heating to cook it!
Old 15-04-2011, 01:22 PM
rhinopower
rhinopower's Avatar
I've done one before, pretty sure timing belt does have to come off tho!
Old 15-04-2011, 01:38 PM
f1bash
f1bash's Avatar
Default water pump
Hi i was very lucky no over heating pulled up every thing great then horrible noise smoke from belt turned engine off could see water pump pully was siezed cut belt of engine sweet as a nut. I know that it states in the manual timing belt needs removing but i have seen about three posts where with a bit of fiddling the pump can be installed without taking timing belt of. If any one can give me a run down how to take the pump of and replace it would be a great help. f1bash
JoeyBoyden
26
04-01-2024 02:36 PM
j.hammond1
30
31-10-2021 05:28 PM
coozer
Ford Focus Range
15-08-2015 10:26 PM
track.focus'd
26
12-08-2015 05:53 PM
lockie
31-07-2015 10:03 PM
Quick Reply: water pump 1.2 zetec engine remove & Replace
