S2 RST won't start without pushing flap down?
Old 17-12-2016, 09:38 PM
crash&burn
crash&burn's Avatar
Default S2 RST won't start without pushing flap down?
Hi guys I've had my S2 for a few weeks now it has had a mis-fire and low revs and on boost, but it broke down the other day, I have got it back so i can start ticking off boxes to get it sorted, pump relay, pump, timing, adjusted the lifters (has soild) etc. I can only grt it to run with the flap held down and it still sounds like it misses when i rev it (don't need to hold the flap once running) the flap does bounce when it sounds like its missing if that makes sense?
Been pulling my hair out so any help would be great
Old 19-12-2016, 08:31 AM
sseeaann1
sseeaann1's Avatar
I had a similar problem with mine a while ago. Needed the flap under the air filter held open to run.
I ended up removing the small block on the metering unit where the 4 red pipes that go to the injectors bolt too and changing it for a spare I had. It's held on by 3/4 small Torx bolts I'm sure.
Could always try removing it and making sure the fuel galleries are clear and not blocked up.
Just a thought. Hope you get it running.
I recently changed from MFI to EFI Defo worth a look these days as parts for the old system are getting hard to come by.
Old 19-12-2016, 07:13 PM
crash&burn
crash&burn's Avatar
Cheers for the reply Will give it a try anything is worth a go :/ was looking at efi/cossie management but the parts dont come up very often.
Old 19-12-2016, 07:23 PM
sseeaann1
sseeaann1's Avatar
I got the EFI inlet off a guy on here then just bought a megasquirt ecu and Defo a big improvement over the MFI.
Good luck getting it running atleast over the winter will give you time to see what's up.
Old 20-12-2016, 07:21 PM
smiley
smiley's Avatar
Had this on my old s2 be for I went efi metering unit shagged
Old 23-12-2016, 09:47 PM
project rs
project rs's Avatar
Sounds like your air fuel mixture is out, when was the last time it was set up properly as they are prone to going wrong quite easy
