VIN PLATE MiSSING ON Escort rs turbo s2
Old 06-12-2016, 09:57 AM
kb1975
kb1975's Avatar
Default VIN PLATE MiSSING ON Escort rs turbo s2
Hi peeps if VIN plate is missing on Escort rs turbo s2 where else can i find the vin numbers on it please ?
Old 06-12-2016, 09:59 AM
haz87
haz87's Avatar
Do you mean its missing off the floor pan by drivers seat
Old 06-12-2016, 10:01 AM
kb1975
kb1975's Avatar
Hi on front slam panel the plate is missing
Old 06-12-2016, 10:12 AM
haz87
haz87's Avatar
Ok, in which case the VIN is stamped on the floor by the drivers seat by the inner sill. Usually found under a convenient flap in the carpet
Old 06-12-2016, 10:17 AM
kb1975
kb1975's Avatar
Thought that be chassis number only
Old 06-12-2016, 10:26 AM
haz87
haz87's Avatar
Thought they were one and the same
Old 06-12-2016, 10:27 AM
It is chassis number only there as you say ,on the vin plate the only other stuff is weights etc colour code and engine number ,contact a user on here called monster as he does vin plates in stainless steel
kb1975
kb1975's Avatar
Not sure can you check or may be someone be long soon to say
Old 06-12-2016, 10:33 AM
kb1975
kb1975's Avatar
Hi looking at buying it but vin plate is missing so if chassis number is stamped on floor is that ok
Old 06-12-2016, 11:08 AM
I would do all the normal checks on the car hpi etc ,sometimes if the car had a front panel people forgot the plate and it was chucked away on the old panel ,if the floor looks tampered with walk away
Old 06-12-2016, 11:19 AM
kb1975
kb1975's Avatar
Hi I have done hpi check all clear but got give chassis number v5 sereil number and some else so check chassis number on floor then I'm guessing needs original floor pan
Old 06-12-2016, 11:32 AM
kb1975
kb1975's Avatar
Orginal floor with chassis number on it
Old 06-12-2016, 11:48 AM
155lee
155lee's Avatar
Usually it's the floor number missing and the bin is there.
IFC the engine number is stamped on a square flat bit of the block above the alternator,check that and see if it matches the v5.
Old 06-12-2016, 12:09 PM
kb1975
kb1975's Avatar
Any pics guys show me what I'm looking for cheers
Old 06-12-2016, 05:50 PM
Adam-M
Adam-M's Avatar
I'd make sure the floor vin doesn't have signs of welding ect, have a look of it from underneath aswell. HPI report being clear is only half of the battle really.
Does the seller offer any reason to why the vin is missing?
Old 06-12-2016, 07:09 PM
MONSTER
MONSTER's Avatar
Ł20 says it's the usual line of 'the body shop lost it'.
Old 06-12-2016, 08:36 PM
kb1975
kb1975's Avatar
Do body shop's always lose them is it not usual for them to do so
Old 07-12-2016, 05:41 PM
mattman1234
mattman1234's Avatar
its pretty easy to find,
just a flap in the carpet,,
https://uk.images.search.yahoo.com/i...b.avg._.1016tb
Old 07-12-2016, 05:43 PM
mattman1234
check on the underside,that no welding has been carried near or around the stamp.
I learn't that one
Old 07-12-2016, 05:46 PM
james kiely
james kiely's Avatar
To be on the safe side bring someone who knows these cars with you to inspect it.
lots of ringers out there mate
Old 09-12-2016, 08:21 AM
steppy
steppy's Avatar
definately check it thoroughly, i stupidly spaffed my load on a lovely looking s2 when i was young and stupid, i didnt notice that the vin plate was missing when i looked at it, when i noticed checked the floor number and it had been perfectly cut around and some steel welded in, further checks from the vin number on the v5 showed the car up to be a stolen one that was never found from the mid 90s, luckily i returned the car to the seller as i didnt want anything to do with it
Old 09-12-2016, 08:57 AM
TommysKeeper
TommysKeeper's Avatar
Surely the best decision is to walk away. If you have these doubts now what's it going to be like when you decide to sell it. Plenty more out there and if this one's cheap there's usually a reason.
Good luck, John
STeve (10-12-2016)
Old 10-12-2016, 07:01 AM
Moderator
STeve's Avatar
without any firm documented proof of vehicle identity and why numbers were removed Im with John just walk away as ringing/cloning etc was rife back when these were on every street corner
Old 10-12-2016, 07:53 AM
simonmcf
simonmcf's Avatar
Has the car been painted? When I got my car resprayed they took it off and never put it back - does the chassis number at the drivers door match book and does the reg on the book match the indent of the reg on the side windows?
