Payen Head Gasket Quality
Ok, i have a question:
I try Head Gasket from Victor Reinz and from Ajusa... but both are very bad.
I need to buy new head gasket...
I read on some forums that the quality of Payen gaskets worsened in recent years, are true?
The engine are standard,
the engine is original , I only have 1 bar pressure turbo.
What do you advise me to buy? Cometic? Payen?
As above, used plenty of GasketsForClassics/Payen/Ford HG's over the years, all fine. Running a Victor Reinz atm - little confused whats bad about yours, they're at the higher end of the spectrum for gasket quality imo.
So you've blown the fire ring on the same cylinder twice... ever considered there's a problem with the build rather than gasket?
Poor sealing faces on that cylinder?
siscossie
04-09-2016 01:22 PM
