Mahle OE RST pistons - where from?
Found I have cracked ring lands on 2 pistons, so trying to find replacements, just after the OE Mahle standard sized ones. Anyone know where to buy from?
Additionally I've read the gudgeon pin needs pressed out, can this be done and then reused/refitted?
http://www.burtonpower.com/mahle-piston-ford-cvh-rs-turbo-std-cv141a-std.html
Comes with new pins/rings, old pins will be worn/damaged once presses out. New ones are 'swetted' in.
