Forged Pistons Recommendations
Looking for recommendations on forged pistons for the CVH which ones and why….also a lot of the forged CVH ones are STD comp ratio 8:3:1?
CheeRS
CheeRS
jano have been talikng to you via email....so realy looking to go standalone to rid the old mfi i have a set of pec rods and am looking for piston options car will be for road use and i am just looking to have it reliable with a decent power figure
here is the spec engine has been fully lightened and balanced crank flywheel clutch plate head is stage 3 43mm inlets and 37 ex 3 angle seats kent cams CVH 35K stage 3 turbo 55/48 (EFI) head 3” mongoose front mount IC pro alloy rad AP paddle clutch
Ask me a question!
without being blunt for the power your engine will make any forged piston will do the same job as long as the obvious CR and mathematics are correct. So comparing one brand to the other is pointless.
what you need to compare is which piston will give the desired sizes the best.
growlingchim
18
07-05-2016 09:23 PM
yawiejon
07-05-2016 10:43 AM
