early mk3 struts change to later type
Old 28-02-2016, 11:34 AM
alun01443
alun01443's Avatar
Default early mk3 struts change to later type
Can anybody help I have a very nice early mk3 shell with 2 strut bolts I want to change them to later type single bolt. Can I change the inner wing and strut top. I have all the bits for a s1 turbo. I know it will never be an rs but I want it to be the best possible replica. Anybody know who may have the panels to do it pref new thanks
Old 28-02-2016, 11:53 AM
155lee
155lee's Avatar
There's a lot more than just the strut tops.
Rear suspension x member,shorter gutter rails are dead giveaways.
If you wanted to do it you can still find single bolt full inner wings on eBay for about £200 each.
Old 28-02-2016, 02:47 PM
alun01443
alun01443's Avatar
Hi thanks Lee I've already done gutter rails and rear suspension it's the inner wings I really needed to know about
Old 28-02-2016, 03:13 PM
alun01443
alun01443's Avatar
Default will mk4 inner bays and struts go into my mk3
I have a mk4 escort xr3i could I cut out the inner wing and strut mount panel and put it on my mk3 to convert it to single bolt strut thanks
Old 28-02-2016, 05:50 PM
155lee
155lee's Avatar
Probably,if you have done all that work already I'd imagine it would be easy for you to figure out and do.
The a posts are different too,s1 has a single bolt door check strap,early shell has a 2 bolt strap.
Old 28-02-2016, 08:36 PM
alun01443
alun01443's Avatar
Hi Lee I have no idea about the differences I bought the car as the shell was very clean I knew about the struts being different but wasn't too bothered as the car is for me and not for sale. My mate is going to do the work and he had suggested we should do the struts to make a better replica. My concern is will the mk4 inner bay fit and are there any other problems I might have using the earlier shell
DixieTheKid
27-06-2016 06:51 PM
Matt_16v
43
10-03-2016 05:21 PM
fordnutsboltsclipsscrews
21-02-2016 08:53 PM
JoeyBoyden
14-02-2016 07:42 PM
Quick Reply: early mk3 struts change to later type
