2.1 zvh
Old 20-02-2016, 01:18 AM
kyam786
S1 RST LUV
kyam786's Avatar
Default 2.1 zvh
Would anyone know a price on a 2.1 zvh whith new mahal Pistons ,rings steel rods new crank shaft lightened and balanced flywheel it's a new block stage 4 big valve head vernar pulley efi inlet with l8 cossie management no gear box with the engine what's it worth thanx Rs lovers
Old 20-02-2016, 03:21 AM
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
not sure on price but i would be very interested in it
Old 20-02-2016, 02:30 PM
kyam786
S1 RST LUV
kyam786's Avatar
I'm getting it for my s1 from a mate 1,500 is it a good price
Old 20-02-2016, 04:55 PM
studabear
studabear's Avatar
If the engine is a known good reliable well built unit and the management is complete with everything required to make it work then it sounds a decent price. Some people pay around that just for the management package.
Old 21-02-2016, 06:43 AM
little bram
little bram's Avatar
mahle Pistons? With steel rods.
Old 21-02-2016, 11:25 AM
muz
Wye Valley Hardcore
muz's Avatar
What camshaft is in it also? As if you need to replace that your looking at nearly Ł300.
Any turbo on it?
Also, as Bram said, Mahles on steel rods... I'm guessing it's 2.1 (86mm) they are Vauxhall Pistons, which you can get steel rods for but would probably have been a custom order as they have a small little end (21mm), but check what Vaux pistons they are as LET Pistons give too low a compression ratio on ZVH's. You need XE pistons, and the 86P serialised ones at that as those are the "squeeze cast" Pistons. Not forged, but better than standard cast.
Best way is whip the sump off and have a look at what's actually there, not what's said is there. I did when I bought my bottom end. Wouldn't hand over the cash until I'd physically checked and as they had nothing to hide they were more than happy.
I've seen a few ZVH's listed over the years claiming to run "LET" Pistons...
Old 28-02-2016, 12:16 AM
kyam786
S1 RST LUV
kyam786's Avatar
hi muz whats the difference between a inlet manifold that has EFI on it to the one that bees plain
Old 28-02-2016, 07:50 AM
muz
Wye Valley Hardcore
muz's Avatar
You'd have to put some pics up mate. A "plain" manifold could be anything. Do you mean the EFI and MFI manifolds?
Old 02-03-2016, 08:26 AM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
I think that sounds too cheap, as Stu said people pay that just for the management (they shouldn't but they do! lol), then there's a new crank and block, new rods and pistons, etc... Doesn't sound right to me?!
Old 07-03-2016, 08:11 PM
rsmadgt3071
rsmadgt3071's Avatar
[QUOTE=kyam786;6659613]hi muz whats the difference between a inlet manifold that has EFI on it to the one that bees plain[/
where you from in birmingham ..i may know you .. are you from near saltley ends..i know quite a few people with series ones in bham.. and i know someone with the running gear and management if you want a guranteed good one pm me
col93saphcos
21
05-03-2016 10:12 AM
Robliddle
14
21-02-2016 04:20 PM
James Porter
19-02-2016 08:42 AM
jimhc
18-02-2016 09:28 AM
Prince_Thain
15-02-2016 07:41 PM
Quick Reply: 2.1 zvh
