Bearing clearances?
Bearing clearances?
Am on building my old zvh back up am measuring the mains and big ends but the measurements I got from work (ford) are different from what ave seen on the net. Anyone got any measures I can compare with?
Ford
<a href="http://s382.photobucket.com/user/littlebram1/media/55337AD1-7926-4120-BBD4-2F37D07ADC6C_zps8drlo6so.png.html" target="_blank"><img src="http://i382.photobucket.com/albums/oo264/littlebram1/55337AD1-7926-4120-BBD4-2F37D07ADC6C_zps8drlo6so.png" border="0" alt=" photo 55337AD1-7926-4120-BBD4-2F37D07ADC6C_zps8drlo6so.png"/></a>
Net
<a href="http://s382.photobucket.com/user/littlebram1/media/D3CD4BB2-02FC-4DEF-9F65-08D128ED64CC_zpsm969ifhu.png.html" target="_blank"><img src="http://i382.photobucket.com/albums/oo264/littlebram1/D3CD4BB2-02FC-4DEF-9F65-08D128ED64CC_zpsm969ifhu.png" border="0" alt=" photo D3CD4BB2-02FC-4DEF-9F65-08D128ED64CC_zpsm969ifhu.png"/></a>
<a href="http://s382.photobucket.com/user/littlebram1/media/Mobile%20Uploads/29258110-9809-4D9A-AA88-2B5C42A1665B_zpsgulc39we.jpg.html" target="_blank"><img src="http://i382.photobucket.com/albums/oo264/littlebram1/Mobile%20Uploads/29258110-9809-4D9A-AA88-2B5C42A1665B_zpsgulc39we.jpg" border="0" alt=" photo 29258110-9809-4D9A-AA88-2B5C42A1665B_zpsgulc39we.jpg"/></a>
Ford
Net
<a href="http://s382.photobucket.com/user/littlebram1/media/Mobile%20Uploads/E92FCC56-4E90-437E-87CE-A93B6EDCFA45_zpspvavihpi.png.html" target="_blank"><img src="http://i382.photobucket.com/albums/oo264/littlebram1/Mobile%20Uploads/E92FCC56-4E90-437E-87CE-A93B6EDCFA45_zpspvavihpi.png" border="0" alt=" photo E92FCC56-4E90-437E-87CE-A93B6EDCFA45_zpspvavihpi.png"/></a>
The bearing clearances typically listed range from way too tight, to way too loose.
I always use 0.001" clearance per inch of diameter journal.
A 2.0" journal would have a 0.002" bearing clearance - this is of course measured.
Hi mate haven't spoke in awhile hope you are well. The problem am having is the big end bearing is out of the ford spec at 0.063mm fords max says 0.043mm but if I go off the other clearances its in spec so don't know if it will be ok.
I am doing well.
0.063mm main bearing clearance is perfect!
That is 0.0024" clearance on a 2.283" journal size.'
I would not run any tighter clearances.
Factory ford clearances are very tight, and are not meant for any high rpm use.
If using tight bearing clearances very thin synthetic oils must be used (0W-20)
Perry
Perry
fordnutsboltsclipsscrews
24-10-2016 08:58 PM
Ford Focus RS Parts for Sale.
21-01-2016 12:38 PM
18-01-2016 05:11 PM
