Rear brake compensator help
Old 11-01-2016, 06:46 PM
Katmat1970
Katmat1970's Avatar
Default Rear brake compensator help
Hello. I am new to this forum. I took ownership of a series 2 90 spec rs in summer. I have started a stripping the rear end ready for some light restoration. I have got the rear brake compensators out. I am struggling to remove the brake lines from them currently. If i cannot remove, what can i fit to replace this set up. I want to keep the rear drum set up and as standard as possible. There appears to b loads of info about bias valves etc( and in line valves from a ka) but i have no real idea what these are. Is there an idiots guide on what i can put in place if i cannot save the original compensators. I will be posting pics along the way so would appreciate comments and thoughts. ( ( (when i know how to do it from my phone gallery)Thanks
Attached Thumbnails Rear brake compensator help-20150627_163709.jpg   Rear brake compensator help-20150627_172253.jpg   Rear brake compensator help-20151231_122844.jpg   Rear brake compensator help-20151231_122721.jpg   Rear brake compensator help-20160110_141301.jpg
Old 17-01-2016, 06:50 PM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
The best way is to remove all the brake lines and all components.
Then fit a 22 or 23 rating master cylinder 6 brake lines and the compensators at the front.
These are available from any non ABS mk3/4 escort apart from rs16i or LHD versions.
There are also kits available with full braided lines and compensators etc ready to fit.
Old 17-01-2016, 07:10 PM
I have the ka in line valves on my rs turbo and my track car ,removed all the rear compensator set up and mounted the in line valves on each rear chassis leg bracket,work a treat
Old 17-01-2016, 07:16 PM
Quick picture of one of the valves mounted ,found up on the master cylinder on the ka and fiesta
Old 23-01-2016, 03:12 PM
Katmat1970
Katmat1970's Avatar
Thankyou for replying. Much appreciated. Started off as a light resto but now ended up a full resto. J
There are also kits available with full braided lines and compensators etc ready to fit.[/QUOTE]
Old 23-01-2016, 03:20 PM
Katmat1970
Katmat1970's Avatar
Thanks twins. I did find your thread and very interesting. Havnt made the decision on drums or disks now on the back. Car now almost stripped. Just engine and front suspension to come out
Around window
Been a bodge job previously. Plated over on both sides.
Old 11-10-2016, 08:57 PM
scottw
scottw's Avatar
Nice car,I was going to buy it last yr but lost my job...now looking again lol
Old 21-10-2016, 06:15 AM
B19 JUB
B19 JUB's Avatar
do you have any other compensators on yours or do the lines from the master go straight to those valves?
Old 21-10-2016, 06:47 PM
No just them ones ,i run the standard 25mm rs turbo 2 outlet master cylinder aswell
Old 22-10-2016, 07:36 AM
B19 JUB
B19 JUB's Avatar
with abs or have a brake bias?
Old 23-10-2016, 08:28 PM
Abs has been removed ,no bias just the valves ,no problem at all with brakes ,been on the car many years
Old 24-10-2016, 03:16 AM
B19 JUB
B19 JUB's Avatar
with the 2 outlet master cylinder do they go into splitters then?
Old 28-10-2016, 07:50 PM
Yes the ford ones on the front inner chassis rails
Scott_Rst
15-02-2016 06:58 PM
JoeyBoyden
15
10-01-2016 02:43 PM
BLUEORIONRSTURBO
13-12-2015 08:01 PM
Adam-M
13-12-2015 05:33 PM
TrevCos
13-12-2015 03:16 PM
Quick Reply: Rear brake compensator help
