Steering column brace bar.
02-12-2015, 12:08 PM
Picked up one of these ages ago and while the dash is out I thought I would fit it. However I've no idea where it goes?
Does anyone have any pictures of one fitted?
02-12-2015, 02:04 PM
P8 Managed S1 with ALS
Not sure which one you have but mine bolted to main column stud and other end went to drivers side kick panel . Drill a hole and bolt it in
02-12-2015, 04:22 PM
Its got a 90 degree angle one end, and a fork the other.
I assume you mean the stud on the underside of the column? (as opposed to the ones behind the steering wheel)
02-12-2015, 07:20 PM
Fork end to under the column where it mounts to the bulkhead . Hole end to kick panel
dickdastardley
Ford Escort RS Cosworth
05-02-2016 11:42 AM
cossie09
09-12-2015 03:23 PM
fordsteve77
Escort Range
27-11-2015 11:27 AM
cossie09
25-11-2015 08:27 PM
cossie09
25-11-2015 07:55 PM
