Custom Rs turbo inlet manifold
Does anyone no were or someone that can do custom inlet manifolds for my escort rs turbo wanting to be running 400bhp + and want to do away with the over engine charge pipe
Engine?
It's flat out not much else I can get on it lol am running 300 + at the moment and just on with changing my management and sorting my inlet manifold out then will see how well it holds together lol
oh right, what u done bout oil pump? what u done bout valve train? what u done bout head lifting ? what u done about block?
what cam and turbo u using ?
u on mtx box?
Am just running burton high pressure pump at the moment it's got a burton cnc head Newman cam solid lifters arp studded block and it's got a t3 hybrid turbo done at cr turbos it's got all sorts am not out there to brake records and to have it last for ever I use it in summer in nice weather so that means 2 weeks of the year lol am just going to see what I can push out of it as my times costs me nothing and I love seeing what can be got out of the smaller engines
pump will be a problem
head will still lift
needs different turbo
what size boost pipes , intercooler
what size exhaust system and down pipe u running( id hope your already on cossie t3 and down pipe)
i had loads of problems with rockers , studs , caps , collets all failing and dropping valves
id be phoning owen developments or turbo dynamics and asking them that. tell them wat u want and trying to do and they get some custom built turbo for u but be 1500-2k i would think
Yes I might get it up a bit when it next comes to peaces will see lol what size exhaust housing would you say I will need to get 400 will it need to be a 63 or would I get away with a 55
I will be lifting my compression it was a so called expert who said it needed to be that low so that will help get rid of some of my lag I will ring up about the turbo tomorrow and am on with sorting the manifold now
simontrayler
22-03-2016 09:45 PM
lockie
15
16-10-2015 09:59 PM
