Brake line advice
Brake line advice
Hi Guys, just after a little advice.
I'm fitting rear cossie discs, standard rs turbo fronts (for now) with no abs nor rear proportioning valves. With 2 outlets on master cylinder. (Im aware the rear could be overpowered, hence the next question!)
just about to run new copper lines all over, am I best...
1) each outlet from m/c to an inner wing, then T to a front caliper and opposite rear caliper.
Or
2) one outlet from m/c to fronts. One to rear with a bias valve. (If this is the case, do I need to T the front symmetrically for equal pressure?)
I guess the symmetrical question would also apply to option 1...?
Opinions and advice greatly appreciated, thanks guys. Andy
Or
Can you tell me if my T between calipers needs to be dead centred? Ie exact same length of copper from t to each front caliper? Same for the pair of rears...
I'm also hunting for a bulkhead/brake bar pedal grommet. Where the hell can I find one? Do they share same part with any other ford?
simonmcf (22-10-2015)
My Advice would be to pay someone professional to do it for you.
If you are putting bigger discs on the back, put bigger discs on the front to keep braking performance in proportion. The last thing you want to do is lose control due to the things that are meant to give you control over your speed!
Thanks Simon, after lots of research across various branded forums this seems like the best option.
Russ Payne
25-09-2015 08:29 PM
