ERST,, Totally strip engine bay. Clean up. Replace engine. Rebuild old engine
Old 29-09-2015, 08:20 AM
Mc5506
Mc5506's Avatar
Default ERST,, Totally strip engine bay. Clean up. Replace engine. Rebuild old engine
I'm currently gathering bits before I completely strip the engine bay on my 88 erst. I've bought another bare engine as my head gasket has gone besides the engine I've bought is polished and ported. And fitted with a stage 3 piper cam 😃👍 so I'm replacing the engine but while I'm at it. Planning on stripping the engine bay and giving it a good freshen up.
Then once that's finished I'm planning on rebuilding my old engine
I've never undertook a task of this magnitude 😱 So I'm shitting myself haha
Any help or advice would be greatly appreciated
cheeRS
Old 29-09-2015, 08:38 AM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
Welcome to the forum
Just take your time, be methodical, pay attention to where everything goes (take pics, label things up etc), having a Haynes manual will help too.
Always lots of help and advice on here if you get stuck too mate.
Oh and before fitting your replacement engine it might be worth dropping the sump and inspecting the shells/crank... nothing worse than fitting an engine only to fire it up and find it's knackered (unless you know it's good of course).
Mc5506 (29-09-2015)
Old 29-09-2015, 08:54 AM
Mc5506
Mc5506's Avatar
Thanks mate. I got it off a good trustworthy friend of mine who assured me it's a good one and his word is usually good ha ha he's a clever bloke as well and knows quiet a bit.
One thing that's puzzling me. The injectors on my engine that's fitted now. Are loose I can wiggle them when I wiggle the fuel pipes. I'm assuming their not meant to be like that are they
Old 01-10-2015, 12:20 PM
mentalasanything
mentalasanything's Avatar
You have assumed correctly!
I had this on my old ERST, caused a poor idle amongst other things.
On mine, the plastic sleeves that hold the injector down had gone brittle and started breaking up. But also the retaining clamps had rusted and broken. I just bought a new set of sleeves, o-rings and retainers and it was right as rain.
Like these:
http://www.ebay.co.uk/itm/Escort-Mk3...item2359602c3e
http://www.ebay.co.uk/itm/FORD-ESCOR...item19e8c6e79a
Can't find the sleeves on thebay, but they can be seen in this pic with the yellowish plastic:
Very simple to replace, I think the injector even stayed on the pipe.
Lee
Old 02-10-2015, 11:28 AM
Mc5506
Mc5506's Avatar
Thanks mate
I've just ordered a head gasket set. I don't suppose you would know if the o ring seals come in this set do they.
Just thought I'd ask before I order more
Thanks again mate
Old 03-10-2015, 11:31 AM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
I've never had any come with a HG set no.
Old 05-10-2015, 09:57 PM
Mc5506
Mc5506's Avatar
Thanks mate. I will order some 😃ðŸ‘
RUBY123
22-10-2023 12:04 PM
j.hammond1
30
31-10-2021 05:28 PM
Wilsfoci
15
30-03-2016 10:26 PM
manuel boeckx
13
03-10-2015 02:29 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: ERST,, Totally strip engine bay. Clean up. Replace engine. Rebuild old engine
