escort rs turbo boost pipe blanker
Just a quick one the top boost pipe mind has a dump valve does anyone no where I can get a blanker plug as don't want the dump valve no more
Also will I not need to do some thing with the boost pressure release pipe that comes off that dump valve or is there another one some where
Oh I see what ya mean and can just take that pipe straight to where it needs to go now. thanks for that got a cossy cone fitter on there so gonna see what the chatter is like as the dump valve ya can't even here it ice one
Right took dump valve off and there was a t piece the other part of the pipe gos to the boost gauge by the looks of it .That now don't work cause no dump valve and there is hardly any chatter at all just wanted to make sure what I have done is right
Spanner monkey
So if you remove the t piece, you'll need either a straight through connection to join the two pipes, or a new piece from the manifold to the gauge.
And if you've got an escort Rst on mfi, you won't get chatter as the metering unit has a flap in it that closes!
Sorry I didn't put that down mind is efi I converted it about a year ago and I have done that just put a connector in so then gos off to boost gauge that's ok then least I no that's ok. Maybe not getting a lot of nice due to big cone filter which I had to have to do the conversion and running standard boost
This will open a can of worms, but surely running a dump valve keeps life a little kinder for the turbo, as opposed to running without one with increased boost levels. While the noise produced from the compressor is great is that not the sound of the turbo attempting to stall due to the air having nowhere to go?
While I am all for great noises I also try to be one for longevity .
Yea I no what ya mean but mind is complete standard efi engine bar the t3 turbo off the escort and running bog standard boost so should be ok up to a certain level of boost not amazingly clued up on this stuff to be honest
muz
16-08-2015 12:57 PM
