fuel pump relay
Old 21-06-2015, 07:26 AM
dlwarrior
dlwarrior's Avatar
Default fuel pump relay
Hi
Im on the look out for a series 1 fuel pump relay . can anyone point me in the direction of where to get one.
Or is there a way around it
thanks
Old 29-06-2015, 10:16 AM
XR2
XR2's Avatar
Depends. Ford still stocks the pink relays which were also used for MK4 MFI Escorts. RS1600i had a different relay (black with a fuse on top) which is out of stock.
When you have trouble finding a correct one, you can also use any standard relay. But then you'll have to rewire it and might also use a different socket AND your fuel pump won't prime then.
Old 03-07-2015, 09:17 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
unless you have a concourse type car I would fit a fuel pump re wire kit off the likes off matt lewis.
lets face it you could buy an expensive rare relay for it to fail in x amount of time or worse it dont work when you get it.
im constantly re wire pumps on many cars not just fords. They suffer with volt drops and high resistance at the best of times. 1v lower at the pump could cause a whole load of crap when tuning.
Old 04-07-2015, 10:39 AM
marky_g
Fleet Manager
marky_g's Avatar
+1 for the rewire kit
Old 05-07-2015, 08:42 PM
Vicar
Vicar's Avatar
Excuse my ignorance but what is the re wire kit?
Just had to replace the relay in mine
Old 06-07-2015, 07:02 AM
Versus_Creations
Ask me a question!
exactly what it sounds like.
a kit that re wires the fuel pump uaing a new relay and loom so no power is used on old wires for fuel system.
Old 26-10-2015, 07:01 PM
moesin2005
moesin2005's Avatar
do these do away with original relay and cant seem to find them on matt lewis site anyone have a link
Old 21-09-2016, 10:12 AM
Steverobbo
Steverobbo's Avatar
Any help would be appriciated im in the same boat my relay has given up
Thanks steve
Old 21-09-2016, 12:43 PM
costina
Live long and prosper!!
costina's Avatar
Thanks steve
I have 2 relays
Old 21-09-2016, 01:18 PM
Steverobbo
Steverobbo's Avatar
Default Relays
Originally Posted by costina
I have 2 relays
Are they forsale ?
I would buy the pair are they silver
thanks steve
Old 21-09-2016, 02:46 PM
costina
costina's Avatar
Are they forsale ?
thanks steve
Purple are they the same?
Old 21-09-2016, 03:20 PM
haz87
haz87's Avatar
Purple are S2, different pin output/design to S1.
Think S1 shared the same relay as Golf GTi's of the era (16v i think... maybe 8) so VW sources/forums are a good shout too
Old 21-09-2016, 03:26 PM
Steverobbo
Steverobbo's Avatar
Thanks for that I believe there is a conversion available
Old 28-09-2016, 06:41 AM
sbeube02
sbeube02's Avatar
Hello, these relays are easily fixable if you are good at soldering. I have repaired several for friends.
Old 28-09-2016, 11:33 AM
Steverobbo
Steverobbo's Avatar
Thanks for the info all running correctly now
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
15
07-10-2015 03:43 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: fuel pump relay
