Ingnition ecu wires help
hello everyone,
Yesterday I was looking at the wiring diagram of my erst2 and I noticed that from the ignition ecu starts two wire that are called: KNOCK THRESHOLD ADJUSTMENT and LOW OCTANE ADJUSTMENT (pin 11 and 23)
for curiosity I went to see on the loom of the car and I saw that these two wires are cut.
does anyone know if this is normal or must be connected to something?
replace knock sensor
Goodmorning
recently my knock sensor does not work more properly . unfortunately I can not find it , does anyone know if you can put something to simulate the sensor , for example a resistance ???
I had thought about it but I don't have the second ect sensor and I don't know if the first ECU need this
Mark RS
12-10-2015 06:01 AM
