My first RS turbo project
Old 27-05-2015, 08:29 PM
  #41
3i Jim
3i Jim's Avatar
That looks more like an xr3i distributor. I might be wrong but I think an rs turbo distributor doesn't have the vacuum advance module.
Old 27-05-2015, 08:31 PM
  #42
RSmark84
RSmark84's Avatar
Originally Posted by Patrick.usn
So I was thinking about getting this one. Because the ones at burton power are on back order. Will this do the trick?
http://www.ebay.co.uk/itm/FORD-ESCOR...item27f01727cb
No because that seller is an idiot, Thats not an RS turbo unit. Looks like an XR3i/Orion 1.6i Ghia one.
Old 27-05-2015, 08:35 PM
  #43
RSmark84
RSmark84's Avatar
just done a search for you, there appears to be many idiots on ebay selling RS turbo ones that arent RS turbo ones. Theres only 1 on ebay and that is used and collection only.
Old 27-05-2015, 09:31 PM
  #44
Nosmonkey
Nosmonkey's Avatar
The one up for Ł65? If you read the description it says he will post it.
Old 27-05-2015, 09:39 PM
  #45
RSmark84
RSmark84's Avatar
Um:
ford escort rs turbo s1 & s2 dizzy with recent rotor arm
dizzy is fully working , good condition, plug is perfect
Questions welcome, o7892 8ll 788 Can Post For Costs
UK Bidders only ,
Old 27-05-2015, 09:42 PM
  #46
RSmark84
RSmark84's Avatar
Here you go found one, Its used. But the listing says will post to other countries:
http://www.ebay.co.uk/itm/Mk2-XR2-di...item33a31f03ca
Old 27-05-2015, 09:57 PM
  #47
Nosmonkey
Nosmonkey's Avatar
If needs be I don't mind having it sent to mine and could then ship it to Spain. Don't imagine postage would be much to there as its within the EU, probably around Ł15
Old 28-05-2015, 09:57 PM
  #48
Red_bull
Red_bull's Avatar
@RSmark84 you said you swaped the whole unit and ignition timing didn't change? The unit has two slotted holes to adjust ignition timing or are you not talking about taking the whole unit of?
As i want to swap mine as well your assertion is quite interesting to me
Old 28-05-2015, 11:03 PM
  #49
RSmark84
RSmark84's Avatar
Nope never timed since fitting it. Marked up where the old one was and fit the replacement exactly as the other one, checked, It with a strope light just to confirm. It was fine....Its been off several times since for maintenance etc and always put back on exactly as rremoved.
Old 30-05-2015, 09:12 AM
  #50
Patrick.usn
Patrick.usn's Avatar
Ok, bought the one rsmark84 suggested. It will probably take like a week and a half to get here. On another note I hit a brick wall on getting recaros. There's a car with a set of nice ones about 4 hours away with a blown motor. I may ask him if he will trade seats plus like 500 euro. Other than that I think I'm taking a road trip in a van to the UK.
Old 30-05-2015, 10:00 AM
  #51
Nosmonkey
Nosmonkey's Avatar
That's probably the wisest thing to do
Old 30-05-2015, 10:57 AM
  #52
Red_bull
Red_bull's Avatar
Now i get it. I thought you ment you just put it on random and timing always stayed the same. So i thought maybe you didn't take of the whole part and left the bit with the slotted holes.
Now we are on the same page again
Old 30-05-2015, 03:12 PM
  #53
RSmark84
RSmark84's Avatar
Did you get the Ghia bolts?
^ yeah better you understand me now.
Old 30-05-2015, 10:23 PM
  #54
Patrick.usn
Yes there on there way right now.
Old 30-05-2015, 10:26 PM
  #55
Patrick.usn
So does any one know where to get the original seat fabric? I found a set of Recaro seats but they need reupholstered. The Recaro emblems are shot too.
Old 30-05-2015, 10:51 PM
  #56
Nosmonkey
Nosmonkey's Avatar
Recaro emblems tend to pop up on eBay quite often, as for the fabric, I remember twins on here had rolls of zolda fabric (90 spec pattern) and the grey bolster fabric for sale a year or two ago, might be worth sending him a message.
Old 31-05-2015, 04:46 PM
  #57
RSmark84
RSmark84's Avatar
If the Recaro badges have lost the silver/white paint, you can use torque paint pens to repaint them.
Old 03-06-2015, 08:04 PM
  #58
Patrick.usn
So I tried to find a thread that twins posted on to PM him to see if he still had it around. However I had no luck. I remember seeing him post before however i can't find where ? O for an update, still waiting on the wheel bolts and dizzy. I thought they were being delivered today but it was just a window crank that I ordered
Here is a like to the seats I found forsale.
http://www.milanuncios.com/motores-d...-162476470.htm
Old 03-06-2015, 08:16 PM
  #59
RSmark84
RSmark84's Avatar
Seats dont look that great for your car... But take a seat from your car, and a Recaro and get them to strip the material from yours onto a recaro and then give them the other 2.
Also looking at your insturment cluster, i'd say your temp gauge looks knackered as that is sitting way to low. You can remove the needle and re-sit it on the lowest point of the 'reading' of the gauge if needed. It just pulls off. be firm and pull of straight, not at an angle.
Patrick.usn (03-06-2015)
Old 03-06-2015, 09:04 PM
  #60
Patrick.usn
Ok, I will try to realign my temp gauge this weekend and let you know how it goes. I just replaced the temp sensor near the distributor. The connector is in very rough condition. One of the pins was broken in half i had to solder the pin. I plan on finding an old harness with a good one and taking it to replace mine. I am pretty sure it is now functioning correctly with the exception of the misaligned gauge.
I was thinking about doing that with the seats. I could probably find the gray material or something close very easily. The stuff that would be difficult to get is the center material. I have never seen a Recaro escort seat in person, so i wasnt sure if there would be enough material from mine to do that.
Old 03-06-2015, 09:07 PM
  #61
nathansRS
c++
nathansRS's Avatar
https://passionford.com/forum/6104282-post117.html
Dave is a top guy -
Old 03-06-2015, 09:17 PM
  #62
Patrick.usn
Something else i did that I thought would be a good idea was to repair the collapsed arm rest on the door panel with a fiberglass repair kit. I just took off the door panel and fiber glassed over the back of the damaged area. It looks better than it was but it just isn't perfect. It can function as a arm rest now with out my arm sliding off of it. I can get good ones shipped to me from ebay. When I get new ones I am definitely reinforce the arm rests on the panels to ensure that they don't sag. I have other things i am worried about right now that is a little down the road. Can you convert those windows to power? Or would it be too much trouble?
Old 04-06-2015, 04:52 PM
  #63
Nosmonkey
Nosmonkey's Avatar
Electric windows were an optional extra for mk4s, nearly all RS Turbos had them so should be fairly easy to get the electric window set up from a car being broken for parts or in a scrapyard near you
Old 04-06-2015, 07:00 PM
  #64
RSmark84
RSmark84's Avatar
Keep the winders. Electric are a hassle, slow and it'll cost a few coinage to buy all the parts. Plus you'd be left with a hole in that door card(unless you did get a replacement.
Also the door pulls are different and you'll never be happy with buying a pair of 2nd hand ones. Plus very very expensive for very good/excellent ones.
Old 04-06-2015, 10:19 PM
  #65
Patrick.usn
Ok so sticking with the windups.
Old 06-06-2015, 01:46 PM
  #66
Patrick.usn
So I have have a bud who is looking for a cheap car in Spain. I found another RS with recaros in mint condition. It's a good price. He doesn't care about seats as long as it runs good. But we may go in on it together and I can get the seats. Or I may buy it move my wheels over and sell mine. It's a white s2 1990. It's got power windows and locks and a moon roof. The back window don't pop though.
Old 06-06-2015, 01:47 PM
  #67
Patrick.usn
It's missing the front high beam lights too : (
Old 06-06-2015, 10:21 PM
  #68
RSmark84
RSmark84's Avatar
Whats a moon roof? I also assume you mean the spot lights?
Old 07-06-2015, 09:11 PM
  #69
Patrick.usn
Sorry even though my language is english some terms or words for parts are called something different in America. Like in the USA a bonnet is called a hood. But any how its a window on the roof, also known as a sun roof.
Old 07-06-2015, 09:19 PM
  #70
RSmark84
RSmark84's Avatar
Ahh, yes the American language is a bit stupid really, Gas??? its bloody petrol! If it was gas it wouldn't be a fluid substance.
However English people are pretty thick at understanding their own language. I swear foreign people can spell and write better English than your average Englishman.
Anyway moving swiftly on, Your parts should arrive this week?
Old 09-06-2015, 06:11 PM
  #71
Patrick.usn
Haha...., that is true about gas? I like petrol personally if I said that in America people would look at me weird. In regards to the parts I was hopeing for them today. But my mail box was empty : ( I hope it fixes my problem.
Old 15-06-2015, 05:00 PM
  #72
Patrick.usn
Ugh.......got the new dizzy installed it the car wouldn't even start......So I think this one is bad.
Old 18-06-2015, 06:59 PM
  #73
Halo87
Halo87's Avatar
Very nice Escort!
Old 19-06-2015, 05:24 PM
  #74
Patrick.usn
So I had my timing redone by a mechanic it was running pretty well. I messed with a screw/ knob by the throttle body because it was idling poorly but now the. Car runs like shit again. Is this a coincidence or should I stop adjusting things?
Old 20-06-2015, 08:23 PM
  #75
RSmark84
RSmark84's Avatar
What one did you adjust idle speed(spring round the bolt) or the idle RPM(stud with the washer). Both are on the throttle body.
You shouldn't be messing with the idle speed, also the S2 should idle roughly 850 RPM.
Old 21-06-2015, 06:28 PM
  #76
Patrick.usn
Yea it was at 600ish I cranked it up to 800-850. So just for a little update. The wheel bolts got returned to sender due to a wrong address. They are going to have to re ship them.... The Dizzy I bought was bad the car wouldn't start with it in.....I am pretty sure it's the dizzy causing problems because if the car is running badly and you remove the distributor then put it back in the car runs like an animal for about 30 minuets. Then starts running like shit. So I need to find a dizzy or get one of the ones I got rebuilt or something. O also I found out I changed the the thermostat fan sensor not the engine temp sensor. So changed that and fixed a broken wire the thermo needle is now at 0.
Old 22-06-2015, 08:25 PM
  #77
Red_bull
Red_bull's Avatar
Default My first RS turbo project
There are dissy's that need the leads turned 180degr. It won't start and pops and bangs a bit. Then turn them 180 degr
Old 22-06-2015, 10:07 PM
  #78
Patrick.usn
Na....tried that the engine cranked but nothing happened.
Old 22-06-2015, 10:29 PM
  #79
Patrick.usn
Found another dizzy.
http://www.ebay.co.uk/itm/Escort-Fie...torefresh=true
Old 05-07-2015, 02:06 PM
  #80
RSmark84
RSmark84's Avatar
Just read your PM, can you post a picture of your seat subframes. they look the same as the Recaro ones, but cant remember if the low spec/XR seats used the same ones.
Quick Reply: My first RS turbo project
