Help with brakes
Old 26-04-2015, 01:52 PM
simonmcf
simonmcf's Avatar
Default Help with brakes
Yes I have searched and searched and can't find a full answer.
Looking to completely redue the brakes. I have cossie front and rear calipers, have a res bottle from an xr3i and plan to buy a bias valve. I dumped the abs and load valve.
I'm a little lost how to plum it all in. I know to got from back port to bias to a t piece and then the rears but can't figure out the front line set up. Please help!
Old 28-04-2015, 06:36 AM
simonmcf
simonmcf's Avatar
Anyone?
Old 28-04-2015, 11:06 AM
swiftyrs
swiftyrs's Avatar
Got this set up on my RS s1 turbo .....
Saph Cosworth 2wd front and rears to match..
Was running for a while with the standard s1 pipe wrk inc the compensator valves to rears and the oe 22mm master cylinder etc etc ...brakes wer still dodgy ..lol...to much fluid for the 22 to push around the system ....
Swapped to a s2 rst 25mm master cylinder ...this has only 2 outlet's instead of the 4 on the oe mk3 s1 22 ....
So this is wot I did ...got new male and female 10mm by 1mm thread brake pipe ends .....plus 1 male 12mm by 1mm male end for the 1 outlet on the s2 25 mm master ( front brake outlet )....2 10mm by 1mm t piece fittings .....1 adjustable bias valve ( knob type with 10mm by 1mm fitment holes for brake unions ..alot seem to b 1/8 npt..)..roll of new brake pipe...3/16 iirc...standard size jobby.....
Took all brake pipes. Off s1 inc rear compensators and bracket ....fit 25 mm master cylinder to slave cylinder ...fabricate new pipes for front brakes which both go to 1 of the t pieces on the from bulk head in engine bay ..then from their to the 12mm outlet on master ......2nd outlet for rear brakes ( 10mm )...from master round bulk head in engine bay to wer the oe rear compensators used to b to the aftermarket bias valve is mounted ( made a mounting plate ) ..then from that single line down the underside by the fuel line to the end of the floor pans wer the other t piece is fitted for a line each for left and right rear disc calipers ....since all the oe brake pipes wer taken off copied the shapes / profiles to suit the direction wer the r situated on car ..sprayed up to finish off in green to match oe .....bleed system .....set up bias valve on a m8's rolling brake tester ( mot garage ) ...jobs a good un ...car now stops on the button ..��......other alternative is to use a mondeo servo / master cylinder with a Vauxhall corsa 2 to 4 way valve ...bit more fabricating needed with the brake bar and the servo mounting plate though ....
Hope this helps ....
Old 28-04-2015, 12:19 PM
RSmark84
RSmark84's Avatar
See RSOC forum
Old 28-04-2015, 08:20 PM
simonmcf
simonmcf's Avatar
Thanks to both you gents. What was confusing me was looking at some pics they had the t piece on both sides. Thanks again.
Old 05-05-2015, 08:19 PM
moesin2005
moesin2005's Avatar
want to do mine but thought you had to split diagonally not font and rear
Old 05-05-2015, 09:17 PM
simonmcf
simonmcf's Avatar
Not if removing all the old stuff , just one line from bias to rear and then split for both sides.
Old 05-05-2015, 09:58 PM
RSmark84
RSmark84's Avatar
My braking is bang on, Was worried at first but now im driving the car. Its been a bloody good experience, something im very happy to of done.
Old 05-05-2015, 10:06 PM
moesin2005
moesin2005's Avatar
anyone have a link to a bias and how do you set them
Old 05-05-2015, 10:27 PM
swiftyrs
swiftyrs's Avatar
Mark may put a link to the rsoc ...i canna find it ..lol..prob lookin in wrong place ...doh...
Collected most of my info of s1t forum ....thread here wer sum pics r etc...
http://www.seriesoneturbo.co.uk/showthread.php?t=46726
Ebay bias valve I used with the 10mm by 1mm union fittings..
http://m.ebay.co.uk/itm/161328045747?nav=SEARCH
Set up the correct brake pressure for the rears ...roughly 60/40 %...used a mot brake test machine at a m8s mot testing station ...
Old 06-05-2015, 06:04 PM
moesin2005
moesin2005's Avatar
so what takes care of the change in rear load if the compensators are removed
Old 06-05-2015, 09:08 PM
simonmcf
simonmcf's Avatar
I think that's what the bias valve is used?
Old 06-05-2015, 09:19 PM
RSmark84
RSmark84's Avatar
Its in the S2 section, I made a detailed reply to the thread.
Either way you'll only need to use 2 t pieces the front fitted to the o/s wing, the rear t piece can be fitted near the rear suspension crossmember(cant remember correct name), simply t piece it on the o/s and route the n/s across the above panel and up onto the rear chassis leg.
On the other hand you can t piece the rears on the n/s wing and route 2 pipes underneath as normal, and going either way as the handbrake cable is(standard routing)
Just remember, the bias valve needs to be installed before t-piecing otherwise you'll need 2 of them and you'll need to set both up to match eachothers setting. If going bigger discs at the front set the bias valve roughly 40-45% to the rear.
You can see how the bias valve adjustment works before fitting it, you could set it at 50% then adjust as needed(MoT station can advise efficiency on their roller).
Old 06-05-2015, 09:21 PM
moesin2005
moesin2005's Avatar
have you got the link please
Old 06-05-2015, 09:35 PM
RSmark84
RSmark84's Avatar
At the rear, you can see i've binned the rear load compensators and installed the genuine Ford brake pipe clips into the holes that was already there. I may of added one hole for a clip(im sure you can see 3 of the clips)
As I'm running a cone filter, I installed my bias valve in the standard box location. If you want to run with the box consider installing the bias elsewhere. some run them inside next to the handbrake.
Old 06-05-2015, 09:37 PM
RSmark84
RSmark84's Avatar
http://www.rsownersclub.co.uk/rsocbb...post2732102253
Old 06-05-2015, 10:02 PM
moesin2005
moesin2005's Avatar
so how does it determine what weight is in the rear of the car
Old 07-05-2015, 05:08 PM
simonmcf
simonmcf's Avatar
It doesn't self determine, you have to set the valve up. You could also run in line valves off a Ka or use the whole 3i setup.
Old 07-05-2015, 08:24 PM
moesin2005
moesin2005's Avatar
so basic is I need to manually alter it when there is weight in the rear but I could always split the rear lines before the compensators ?
Old 08-05-2015, 07:00 AM
RSmark84
RSmark84's Avatar
Nope set it up, then never touch it again. Not sure why you want to keep the rear load compensators though?
Old 09-05-2015, 10:29 AM
moesin2005
moesin2005's Avatar
they must be there for a reason
Old 09-05-2015, 03:40 PM
simonmcf
simonmcf's Avatar
There are a few ways to change the brake set up if you felt the need to. For example use a 3i set up as this have valves that sit in the engine bay or could use online values for each rear that sit in each rear arch or use a bias like mark has in his pics or you could just leave it and do nothing. Reason I'm changing was my orginal ones were falling apart with rust so decided to go with a bias.
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Help with brakes
