master cylinder and servo
Does anybody know if you can get an rs master cylinder new anywhere or I've been looking up the upgrade options but it's been bit vague is there an upgrade which does just bolt on? Or any how to guides would be much appreciated thanks
No upgrade that just bolts on that I'm aware of.
Mondeo servo is bigger and a good mod tho with a bit of patience/cutting/welding of brackets etc.
Symptoms of failed servo are essentially a big air leak (so shitty idle/lean running etc) and also brake pedal would be rock solid as there would be no servo assistance.
