Karlos G - AKA Frenzy Performance Tuning (FPT)
#41
So let me get this right you had your car mapped on weber managment by jano@oddkiddcreations it pulled hard and was smooth and didnt eant to stop pulling and you loved it? Then your were involved in a pretty big crash i gathered wich fortinatly you walked away from and then you had the car repaired ect then it never ran correctly again?
If so doesnt that point to some kind of witing fault somewhere pehaps? Im not saying it was just saying surley it was a big possibility?
#42
It was installed and mapped by jano@oddkiddcreations i then upgraded ecus
Sent him my new ecu (through the post) he had the same spec car at his workshop he put a safe map on it and posted me the ecu back and i then drove the car to essex and had it mapped for more power and drove back and never skipped a beat i was more than happy with the car/managment and running
And also with the service I recieved.
#43
#44
The crash had nothing to do with the car running shit that was years ago! it had a CPS error @ 5k rpm, as said above james said they don't run correctly half the time this is due to using brackets here and there for sensors. Leave it on a cosworth imo now I've learned. Yeah they can run fine but it was all second hand, I sold it all which paid for a brand new after market stand alone managent with new loom and connectors plus it's got anti- lag / launch control etc etc. you have to pay extra for all this with cossie management which is ŁŁŁ, it's a bloody no brainer.
The leading tuning company in the uk has said it all above! Is that not enough? Am not saying cossie management is wank but it's simply not better than going after market. price it all up for cossie stuff, INFACT a custom map (real mapping) is Ł500 at NMS and similar at MSD which is the price for the after market managent!!!
#45
#49
This thread is a classic example of how PF has gone downhill.
Well done on making a happy customer Karlos. Shame the thread got off topic.
Lee
Lee
#50
Balls Deep!
It is Lee, always someone losing their rag about something or spiting their dummy out!
But it's also good to hear MSD's view on old Cossie management, they are IMO the most reputable tuner in the country, they have by far the best dyno cell too, what they say carries a lot of weight.... There are too many people still stuck in their ways when there are better and more economical options out there, it's good that Jano brought it up!
RSricRS (26-03-2015)
#55
yep totally agree thats why i dont think people bother with it any more , well done karlos i got rid of cossie management years ago dont no why people use it when u can get other never systems at good prices
#59
Spanner monkey
It may have been mentioned and I may have missed it but most people seem to use a cossie CRANK sensor for the cam sensor when doing the weber conversion, Hence at high revs they cause problems as they are right on their limits being used as a phase sensor. Why don't people just use a proper Zetec cam sensor? I always have done.
#60
Agree with that Gadget, I have found the standard cossy crank sensor coil saturates quite easily and doesn't recover in time for the next tooth event when using a 36-1 crank wheel too, a couple of 10K resistors sorts is out and would probably work when using the sensor for cam.
#64
thats slightly misleading for people looking for different management systems. swapping from cosworth management to megasquirt isn't going to make it faster or more responsive or better on fuel its the actual map on either or any management that will give you those things
#65
Whereas you can buy an OFAM ecu for an already running rs turbo plug it in and itl run (90% of the time) then just get it mapped and your sorted
Being that it all works 100% and is alot easier to set up and many many people tune megasquirt it is a great option these days..
And if you read the rest of this thread you would have read that Information in Context and realised they meant whilst cossie management can be a good system it's very hard to get one that's healthy,a decent loom, and all the gubbins and sensors all working 100% to produce a healthy engine and decent map.. What was meant was it is far easier and much better on the pockets to buy an OFAM ecu and stick with your already functioning loom and you could pay for your mapping session all this before youv even paid for cossie managemt with all the swizzle to go with it
#69
You could add another Ł185 on for the innovate wideband but i would of bought that even if it was mfi still
#70
Fleet Manager
I've had an OFAM ecu fitted by Karl very happy with it as its all looks factory under the bonnet, he also fixed lots of starting issues for me TPS fault and PUMP fault
Very very happy with his work and looking forward to taking it back for a remap
#71
300+
Might have Karl build me a zetec turbo then when I've found a decent car ..didn't know he was a business well done on both parts.
Ric when ya coming to wales for a proper detail mate .
Rsmat (07-06-2015)
#73
300+
Sound mate ..I've just asked you to pm me a rough price on building me a zetec turbo mate via PM if you can ..as ill be getting a car in the next few months maybe sooner if a nice white one comes up mate .
Karlos G (08-06-2015)
Rsmat (08-06-2015)
wowk
30-03-2021 07:49 PM
SMILER258
28-09-2015 09:04 AM
