How does this spec sound?
Hi all, going to covnert my 1.8 EFI ZVH to full ZT.
I plan on going down this route then obviously progress later down the line, so the following:
ST170 with Blacktop Head
CVH EFI Inlet on Adaptor plate
T3 Turbo
OFAB with map on it for 1.9 Tall Block, beiges etc
Will that be ok until I start to chase more power again?
T3 Turbo
Dave not Claire.
Ahmed Bajyoo / Mark @ Grove Garage did them for Ian Howell back in the day. Possibly try Ian or Mark. Maybe worth checking cr with them tho. Not aure if they st/blacktop combo would be different to what Ian used to build.
Hi, I was under the impression that ST170 rod bolts are the same as Focus RS items, if not will get some ARP's. Its going in a MK2 Fiesta so will have to check bonnet clearance issues and will try sort a map/chip out then!
Ask me a question!
Your missing vital info.
what pistons do you have
will they allow low cr on a 16v head In turbo form
Why do this to an 1800
Map sensor will only flow for 1 bar of boost which is lame
management is batch firing and not good enough to control a 16v in short
no need for st170 head on 1800 without decent parts inside
Balls Deep!
Read his first post properly.
Balls Deep!
Exactly, but ok no worries Jano I'll make it simple for you..
Does it make sense now?! lol
what pistons do you have He has ST170 Pistons in a ST170 bottom end.
will they allow low cr on a 16v head In turbo form Yes they will with his black top head.
Why do this to an 1800 He isn't!
Map sensor will only flow for 1 bar of boost which is lame Agreed, I would recommend something else.
management is batch firing and not good enough to control a 16v in short This isn't even close to being true.
no need for st170 head on 1800 without decent parts inside He isn't doing that.
Thanks guys. I do understand OFAB is not the best to use on this, but being as I dont fancy forking out thousands in one go for uprated turbo, management etc im gonna get it in and running and upgrade from there.. It will work itself out.. eventually
At the end of the day its going in a MK2 Fiesta, ST170 bottom ends good for 300hp.. Thats all I want. Anymore its pointless. If thats achievable without nailing Ł2k+ on a a base engine then im all game. Sometimes you got to accept that not everyone can afford to do it the "proper" way. Plus all this is paid for with spare cash I have, not my credit card
I re-made my OFAB loom so its pretty much new. I figured by the time I pay for a chip for my current spec (Ł250) it makes sense to sell my OFAB ECU and Chip and put the Ł250 towards OFAM..
Karlos, im going to be ordering OFAM like I said. Ive got a Rover Turbo inlet manifold with 701 injectors in coming my way. So next question, will my T3 turbo be ok for now until I can afford an upgrade?
If so great for now, but what turbo do you recommend to replace it?
Next question, fuel pressure, what shall I run? Standard rail pressure be ok?
Last question, shall I invest in an AFR gauge?
Balls Deep!
Stock fuel pressure and rail are fine.
Fitting a WBO2 and gauge is a good idea if you can afford the extra Ł150.
A Stage 3 T3 is perfect for your build if staying with the T series.
Cheers dude! Ill get injectors after a wideband setup.
For the mean time spec is going to be:
ST170 Bottom End
Blacktop Head with ST Valve Springs
1.8mm Gasket
Rover Turbo Inlet with 701 Injectors
RS Turbo T3 (Standard)
OFAM
Im thinking just set it up for low boost until I can afford a Turbo and Injectors as I pretty much have all the parts ready now bar the ECU.
ST170 Bottom End
1.8mm Gasket
OFAM
At the moment my Turbo is holding 10psi on actuator pressure. Shall I just leave it at that when I fit it to the Zetec motor?
It all started with a simple conversion, now im spending loads haha
Thanks Karlos. Im gonna leave adjusting the boost until I book it in. I dunno whos closer you or Boost Monkeys. Hopefully have the engine in next week!
ST170 Bottom End
1.8mm Gasket
OFAM
ST170 Bottom End
1.8mm Gasket
OFAM
Which of these Widebands do you recommend guys?
http://www.ebay.co.uk/itm/New-AEM-Di...item46139920be
http://www.ebay.co.uk/itm/INNOVATE-M...item43d7373325
