HT Leads firing order position
my HT leads don't match up with the diagram from the mircofibre and haynes manuel which is from looking at the block 1,2,3,4 and looking at the distributor top left 1, top right 2, bottom left 3, bottom right 4
mine doesn't match up the same,
the car starts and runs and have done 18k miles like it but it is a rough start on cold, although starts first time of the key runs lumpy for 15 seconds then purrs nice.
can this have an effect on it??
so just so I'm correct the engine should be set cam TDC piston one, the rotor arm should now face ht lead 1 (top left usually) then order is 1,3,4,2 that correct???
Hi fella, so that's interesting the first picture you put is what I have in the rs turbo microfiber you say it's for non turbo, the second picture with ht1 top right of dizzy is for the turbo dizzy, maybe my ht leads are setup correctly afterall as I was,going to set it up like the first picture!! As I've never seen the second picture before.
The Youth.
30-09-2015 09:59 PM
