wired up some gauges need a dice on ground and ignition
Old 14-02-2015, 06:03 PM
tlr_rst
tlr_rst's Avatar
Default wired up some gauges need a dice on ground and ignition
hello everyone
basically I've fitted oil temp and oil pressure gauges to my erst, have a pillar pod gauge, all plumbing to the sender on a adapter on back of block, tapped into the lights feed from the boost gauge so illuminates nicely.
my question, I'm struggling to work out where to attached the ground wire for the sender, I'm thinking anywhere on the car metal should be ok, just dont know where i can get an ignition feed to attach to that is my biggest struggle right now.
look forward to the replies as ill be cracking on with it tomorrow hopefully
Old 14-02-2015, 07:09 PM
st220kyle
st220kyle's Avatar
ignition feed for stereo?
Old 14-02-2015, 07:11 PM
tlr_rst
tlr_rst's Avatar
yer that could work. just don't know which one the ignition feed is
I've got original ford cassette radio, what colour could it be???
Old 14-02-2015, 07:14 PM
st220kyle
st220kyle's Avatar
yellow or red i cant remember which, you'll have to check with a multimeter
Old 14-02-2015, 07:21 PM
st220kyle
st220kyle's Avatar
it'll be red
Old 14-02-2015, 07:25 PM
tlr_rst
tlr_rst's Avatar
right so hook up to the red wire, use a multimeter to see which gets a feed when turned ignition that sounds good
what about the found, shall i feed from the stereo ground or bolt it to a metal part of the car?
Old 14-02-2015, 08:52 PM
st220kyle
st220kyle's Avatar
Yes i would say so. As for the ground, I cant say either way will make any significant difference over the other. Go with which ever is most practical/ convenient for you to do.
Old 14-02-2015, 09:36 PM
tlr_rst
tlr_rst's Avatar
right cheers fella, hopefully it all works out
Old 15-02-2015, 07:55 AM
RSricRS
Long live the ford RS'S
RSricRS's Avatar
The ignition live on your stereo is yellow. You want the earth as close to the sender unit as possible so I read in the instruction leaflet I got with my stack gauges.
Old 15-02-2015, 09:05 AM
martysmartie
martysmartie's Avatar
Originally Posted by st220kyle
it'll be red
It's yellow, which is confusing as usually it's red and the constant is yellow.
The ground is the sender?
Martin
Old 15-02-2015, 09:18 AM
st220kyle
st220kyle's Avatar
Ok I knew it was one of them but couldn't remember which without checking, which is why I advised to check with a multimeter before hand.
Let us know how you get on
Old 15-02-2015, 04:47 PM
tlr_rst
tlr_rst's Avatar
just wanted to say thanks guys, and thanks for commenting this morning that it was yellow, all sorted now and grounded, heres a photo of my hard work helped by you guys
Old 15-02-2015, 04:50 PM
studabear
studabear's Avatar
I've just fitted a cheapo oil pressure gauge, well I say fitted its not mounted, bloody thing says I have 120psi oil pressure.
I'm opting for the gauges in place of the radio and relocating the radio to the centre console.
Old 15-02-2015, 08:54 PM
st220kyle
st220kyle's Avatar
Nice one, glad it went to plan
Old 21-02-2015, 12:46 PM
martysmartie
What sender did you use?
Martin
Old 21-02-2015, 04:39 PM
studabear
studabear's Avatar
The sender unit supplied with the gauge, I've purchased a better gauge so will get it fitted soon.
Old 22-02-2015, 10:40 AM
Karlos G
Balls Deep!
Karlos G's Avatar
That's some serious oil pressure! If the new gauge reads the same then maybe the relief valve is stuck in the pump, hopefully it's just a crap gauge.
Old 24-02-2015, 06:59 PM
tlr_rst
tlr_rst's Avatar
my cheap gauges and senders came off ebay from china, took over a month to deliver, work well, guess my oil pressure is ok then, does that mean i can mod the engine with more boost???
also is it worth fitting a 'fuel pressure gauge'?
Old 01-03-2015, 02:21 PM
martysmartie
Lol, yes the problem must be the sender, either that or the OP has shorted the ground, or it's a faulty gauge.
The FP is a good idea (which is more important that boost pressure!)
Martin
Old 01-03-2015, 02:24 PM
studabear
studabear's Avatar
Well I've just taxed the car so I will get round to replacing it all.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
IainRS1700T
25-09-2015 06:44 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: wired up some gauges need a dice on ground and ignition
