Cosworth management conversion won't start HELP
#41
Iv read this thread a few times and could make loads of different comments like others have made but i think the best option for you is to get it trailered to someone who knows what there doing professionally and once they have sortes out the running issue they will then be able to map it after.
#44
It ended up been a faulty Ecu after hours of messing about I got another Ecu pluged it in and away it went thanks again everyone for there input and least now I no everything I need to no about the system lol
#45
Ask me a question!
I thought you told me you plugged the map sensor the right way round and it worked?
The ecu cant be switched as easy as your making out as the board wouldnt fit.
Also tested your ecu that you sent me to fit a chip to suit your spec.
either way im glad you got it running.
On the plus side you found out some decent info and help you may not of known before.
Get it ready for the summer and mapped up when you finished the rest.
#46
Yes when I spock to you last I had it running but as you said on the phone with the map on the wrong way round it was rich as hell so I had a another Ecu ordered and when it came I tested with my old ecu with everything plugged on right and stared and stopped them new ecu on and it runs good just needs setting up so will let you no when it's ready for you to do
rog
04-09-2015 12:10 PM
