MFI Wiring Help
MFI Wiring Help
Hi guys, stuck on two bits of my wiring on my conversion. The green wire that goes to the supressor by the coil, one comes from ECU straight to coil, then one comes from coil to supressor then where does the green wire go?
Also I got one wire coming out of the ECU plug, its green and brown and its just in my loom spare. I cant find the pin numbers on the ECU plug so its hard for me to find any info about it? Is there a diagram of the plugs with numbers?
Thanks!
Thanks!
Mark RS
12-10-2015 06:01 AM
