lean on one cylinder (mfi turbo)
Old 06-12-2014, 10:20 AM
mgtkr1
mgtkr1's Avatar
Default lean on one cylinder (mfi turbo)
I have a intermittent problem with a misfire when opening the throttle afterover run. as soon as its open any longer than 2 seconds for example, the misfire goes. I also notice one cylinder is running lean. (plug is whitish, others are the correct tan colour). could the two symptoms be related? Im thinking the injectors are suspect (the lean cylinders injector maybe leaking? anyone have any experience of this? the car needs a setup anyway but I want to make sure any niggles are out the way first. the other thing is it starts on 3 cylinders for a couple of seconds, thens runs on all 4. thanks in advance
Old 06-12-2014, 07:15 PM
j6kyt
j6kyt's Avatar
swap the injectors round and see if the problem moves with the injector
Old 07-12-2014, 04:21 PM
luke19790_3
luke19790_3's Avatar
Have you changed the spark plugs?
Old 07-12-2014, 06:22 PM
mgtkr1
mgtkr1's Avatar
I haven't luke. the plugs are some spare that I had lying around so its definitely due some fresh ones. I just used them as I had them handy upon fitting the fresh motor. something I have overlooked and was on the to do list.
Old 12-12-2014, 07:08 PM
Karlos G
Balls Deep!
Karlos G's Avatar
As said swap injectors and then compare the burn.
Matt Baxter
16-09-2015 08:30 PM
EoinXR3
07-09-2015 05:44 AM
Marcus L
29-08-2015 02:18 PM
marky_g
15-08-2015 10:43 AM
Zoggon
10-08-2015 10:39 AM
Quick Reply: lean on one cylinder (mfi turbo)
