Boost hose clamps...
Sierrasideways (08-11-2014)
Will replace all my remaining clamps with BRIDEX someday.
Every size is possible, really outstanding quality (if not the best), every order is custom made, not a mass product.
Would start a collective order, if there are enough buyers.
Pete frst (08-11-2014)
How about these T Bolt clamps? (maybe not necessarily the spring loaded items).
http://www.turbohoses.com/Clamp.htm
When it comes to boost hoses, Jubilee's are the only way to go. You can google every other type and find forum posts of people having issues with sealing/tightening etc.
Why T-bolt clamps are not as good.
https://www.amsperformance.com/attac...Gear_Clamp.pdf
good quality jubilee clips from the local hardware shop. Cheap, simple, and work perfectly.
A few mates have mentioned this recently, and dont believe i have never blown a boost hose off with 2.5 bar when they are struggling with 1-1.5 bar and fancy expensive clamps.
With a similar clip to my link it was about the only clip which stopped a fuel hose from leaking in my car ; it leaked with the previous owner as well judging by the amount of clips present on the hose (OK, the solution was to buy an entire new hose but for £200, plus dropping the tank? No thanks).
Russ Payne
25-09-2015 08:29 PM
