maxspeeding H conrods on std piston
Old 05-11-2014, 04:31 PM
luxembourgrst
luxembourgrst's Avatar
Default maxspeeding H conrods on std piston
hy how to fix conrods on std escort rs turbo piston
because the new H conrods (burton,maxspeeding ...) are normaly for piston with the gudgeon who spin free in the conrods and clips
and not pressed in
no?? thanks
Old 06-11-2014, 09:35 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
You need to have them modified to work.. But this leads to the next question.
Why spend money making std pistons weaker and risking your whole engine with nice new rods, without buying a set of forged pistons the correct CR for the power your trying to get. Pistons are very cheap now days if you find the correct source.
Old 06-11-2014, 10:41 AM
luxembourgrst
Yes i know. What about the low comp piston from woesner. 7,5:1
My spec is like 220-230 bhp because only have stage 2 turbo. But looking high boost like 18 psi
Old 07-11-2014, 04:38 PM
luxembourgrst
well I searched about what kind of comp are good for escort rs turbo and saw that std mahle rs turbo compression are enough low comp for -300 bhp
but now im fucked up I have the H conrods who only fit flushing piston with clips
but I want to stay in the standard 80mm bore?
what know hmmmmm
Old 07-11-2014, 04:56 PM
luxembourgrst
are this woessner CR 8.3?????? http://www.engine-dynamics.com/Produ...=227&id=104421
Old 09-11-2014, 10:33 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Yes standard CR will be fine as will those Wossner.
Old 09-11-2014, 11:19 AM
luxembourgrst
are all the wossner 8,3:1 CR are was there some kits avaible with 7,5 and 8,3
Old 11-11-2014, 09:21 AM
Versus_Creations
Ask me a question!
There is many choices of cr and sizes available for wossner, supertech, je, accralite to name a few. I prefer some over others for various reasons.
I would go for a slightly lower cr using the mfi setup or if you planned to change management systems in the future then maybe different again.
So really it comes down to your final goal you want to achieve.
If you build this nice forged emgine its a waste on mfi.
Old 11-11-2014, 07:01 PM
luxembourgrst
I know about the mfi
Old 12-11-2014, 03:35 PM
Karlos G
Balls Deep!
Karlos G's Avatar
I agree with Jano, it is a waste, you may as well stay with stock internals.
Old 12-11-2014, 05:35 PM
luxembourgrst
well light piston an conrods also help in the bhp or torque?
there was mfi with 5 injector who get some 260-280 bhp (I know not with a stage 2 turbo ) in know that std piston are good for 300 bhp
but I need to change them because is more cheaper to buy forged piston as transformat the conrods to accept the standar piston...
Old 13-11-2014, 08:30 PM
Karlos G
Balls Deep!
Karlos G's Avatar
If they are lighter you will reduce pumping losses so may free up some power, similar to fitting a lightened flywheel.
Old 22-11-2014, 08:59 AM
luxembourgrst
well here is the diffenrence
Old 26-11-2014, 02:14 PM
Versus_Creations
Ask me a question!
Well done. Now gap the rings proper and check comp ratio with dummy build.
01-11-2015 06:53 PM
20/20 vision
29-09-2015 09:25 PM
deathrider666
28-09-2015 06:12 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: maxspeeding H conrods on std piston
