Think im seeing things
Old 30-10-2014, 06:08 PM
Piston Broke
Piston Broke's Avatar
Default Think im seeing things
Right compression on the engine is 150 psi across all 4, norm when i take the oil cap off engine cuts out etc. I have JUST fit a new turbo a T34 BRAND NEW. Right started the engine as norm and was running, taken the oil cap off and the engine didnt stutter or cut out ? WTF would fitting a new turbo change things like that or has my ring fairy been in the workshop................ any help or advise would be much appraiciated ! oh and done no miles when doing the oil cap off and on the new turbo ...................
Old 30-10-2014, 06:23 PM
3i Jim
3i Jim's Avatar
I thought all escort rs turbos cut out or run lumpy when the oil cap is removed due to the bosch k-jet set up. I might be wrong. It's a bit odd what you're describing, I wouldn't worry about it if it runs fine.
Old 30-10-2014, 06:27 PM
Piston Broke
It runs abit crap due to wanting a setup but that was the same when it did cut out when the cap was removed if that makes sence lol
Old 30-10-2014, 06:36 PM
Piston Broke
Apart from the turbo, i also with a oil catch tank to my baileys pot. the baileys was already on it
Old 30-10-2014, 07:19 PM
Piston Broke
Anyone else ? before i take its head off then my own .................
Old 30-10-2014, 07:59 PM
Karlos G
Balls Deep!
Karlos G's Avatar
It will only run if the breather return to the metering unit has been blocked off or is blocked with crap.
Old 30-10-2014, 08:06 PM
Piston Broke
what if its not either of them.................... rings ? carnt see how tho thats the thing it hasnt moved lol
Old 30-10-2014, 09:41 PM
Piston Broke
So im lost, it runs with its misfire which im sure is injector/s (new coming in the morning) but this taking the oil cap of has me thinking and hope you lot been the blue boys can help or know of it as would love to use it lol
Old 31-10-2014, 07:13 PM
Piston Broke
Any one .............. before the match comes out. Its fine on compression etc an only changed since the new turbo and catch tank was fit between the metering unit and bailys breather
Old 31-10-2014, 09:44 PM
studabear
studabear's Avatar
Have you fitted the catch tank to the port on the bailey breather that would go to atmosphere or the metering head, have you then blocked the metering head port off?
Old 31-10-2014, 09:52 PM
Piston Broke
from the bailey to catch to meter unit dude not blocked off the metering head
Old 31-10-2014, 09:57 PM
studabear
studabear's Avatar
It might be running so rich that the air leak is not causing it to stall.
Old 31-10-2014, 10:02 PM
Piston Broke
like bore wash mate, it was running lumpy and injectors have been tested 1 scrap 3 needing clean got some new ones on the way but my brain was like ARRHH lol. Its like my wife this car love it but god it drives me nuts ! lol. im sure its a simple thing but god help me lol any more its having a cozzie lump fit !
Old 31-10-2014, 10:06 PM
studabear
studabear's Avatar
Sounds like it needs towing to a tuner.
Old 31-10-2014, 10:41 PM
Piston Broke
go with burning it lol, but yer dude going to take it to MSD once i have sorted the stuff i get lol
Old 31-10-2014, 10:49 PM
Piston Broke
Can you answer me one last thing, i understand you can block the metering unit vent pipe and then vent the bottom of the baileys but isnt that just the same as having the oil cap off anyway ...................... o why does it not die when you do that ????????
Old 31-10-2014, 10:54 PM
studabear
studabear's Avatar
The pipe that you block on the metering unit is connected to the breather system if running standard breather, therefore any airleaks created screw with the fueling. If the pipe is blocked off at the metering unit and set up accordingly then the breather system can no longer cause a air leak.
Old 01-11-2014, 12:08 AM
Piston Broke
why not do it that way from new as then the fresh air will be better for the engine right. So in theory your closing the breathing loop and the bottom of the baileys can just have the hose to underside to 'oil' the floor
Old 02-11-2014, 11:44 AM
Si74
Si74's Avatar
Just 'oil' the floor as you say. mines runs like this and I'm sure I read somewhere that putting a filter on the end of this pipe was a bad idea.
07-10-2015 12:56 PM
Mark_
40
02-10-2015 04:40 PM
Fudgey
21
30-09-2015 06:19 PM
rsguy
44
29-09-2015 03:29 PM
Quick Reply: Think im seeing things
