Overheating
Overheating
Hi
Right need some help
I have s2 with a Airtec rad twin fans but the fans only kick when it's really hot but then the header tanks starts to let go
So one is it getting it hot or two is the tank not hold pressure? The tanks after market alloy tank
Roomey
Roomey
going sideways in a fwd
you could try adding a manual fan switch and see if earlier switching helps
, some temp switches can be manually set ,
kenlowe make 1
you can purchase lower opening point switches,
the number of degrees you have at present , is usually stamped on the side of switch
I cannot comment on header tank other than other pressure caps may be available
kenlowe make 1
Cheers for info
Seem to have sorted it think the cap was not fully screwed on due to alloy cover spinning also I may have over filled the header but touch wood alls good
Roomey
Roomey
Ade
08-02-2007 05:11 PM
fiestaturbo1984
19-02-2006 03:51 PM
woodz77
13
06-11-2005 03:02 PM
