focus rs my s2
Plenty of info regarding it on here, have a look through the search section. Will need custom mounts, custom driveshafts, hydraulic clutch conversion, some inner wing/chassis leg modification. Suitable management, some custom plumbing and a few other bits.
Have a look at this, it gives some idea regarding zetec turbo conversion which is what a frs engine is.
https://passionford.com/forum/ford-e...onversion.html
Thanx studabear it's the inner wing/ chassis leg I'm not sure on I will have a look at the link now. Don't won't to chop it to much as the shell is good as just under 50k on it.
The mods to the inner wing are minor to be honest mate. Just need caressing a little with grinder+ hammer and a little welding then a custom mount welding to the chassis leg.
There's a few diff ways to achieve the same result please type of info about in different threads and people's build threads.
As mentioned you will need mounts and custom shafts also aswell as someway to solve the speedo issue as the frs box is electronic speedo
I'm in the middle of this very conversion and it's been nearly finished for over a year!! Need to pull my finger out really but so.times life just takes over!
wowk
30-03-2021 07:49 PM
